Max boost on stock ECU
Old Jan 17, 2006 | 07:40 PM
KY's Avatar
KY
I am trying to find out the most boost I can run before my ECU cuts it off.
I want to run race gas at the track and boost to 23 psi, but was told the ECU won't allow me to boost that high.
I am going to get a dynoflash and Greddy Profec B II. Trying to figure out which one I should get first.
Thanks
Old Jan 17, 2006 | 07:48 PM
Warrtalon's Avatar
1) Fuel cut is not a function of boost, but rather a function of airflow. It just so happens that more boost means more airflow, so you usually see fuel cut at higher boost levels. There is no pre-defined boost level that will cause the ECU to cut fuel, though. I ran 23, 24, 25, 26 psi without fuel cut on race gas, but my SAFC was allowing me to fool the ECU into thinking it was seeing less air, so that basically delayed fuel cut to beyond what I was running at the track.
2) After you get Dynoflashed, there is no more fuel cut whatsoever.
Old Jan 17, 2006 | 07:54 PM
RREvo's Avatar
What year is your EVO ?
My is 03 and I didn't have any problem boosting to around 22 maybe a little more running the XEDE without XEDE Flash , when I was going to run anything above 23 psi the boost cut off .
Old Jan 17, 2006 | 08:34 PM
11secEVO7's Avatar
yeah i have run up to 25psi easily on my E7 with stock ecu
Old Jan 17, 2006 | 08:56 PM
yesevo's Avatar
i m running 29psi on stock turbo no problem here!
Old Jan 17, 2006 | 10:25 PM
Turd Squirter's Avatar
me too
Old Jan 17, 2006 | 10:26 PM
Warrtalon's Avatar
He didn't ask about the stock turbo. He's asking about fuel cut on the stock ECU.
Old Jan 17, 2006 | 10:36 PM
Nosjunke's Avatar
Don't cry when you melt the turbo.
I have my settings on the Profec at 21 'lo' and 27 'hi'. Also I have the 280 cams, and many other mods. My warning is set at 28psi.
Old Jan 17, 2006 | 10:43 PM
elhalisf's Avatar
before i got the flash, i was getting boost cut at 23-24psi spike in my 04 with 10.5 hot side and intake. i thought that was way too early
Old Jan 17, 2006 | 11:04 PM
BURNALL_4's Avatar
he wont hurt that turbo my friend ran 32psi (not efficientally) but it did. he had no problems + a 75 shot btw this was an race gas.
Old Jan 18, 2006 | 12:21 AM
DreamLike1's Avatar
Anybody who's smart (cough Warrtalon cough) could you answer me this:
If I just purchased an MBC, say forge... Could I turn the boost to 25 and run on 91oct day-to-day with NO OTHER mods?
Old Jan 18, 2006 | 02:51 AM
Alias's Avatar
No, I would not recommend that at all on 91 oct. Unless you are running alky/water injection, or race fuel.
Old Jan 18, 2006 | 05:04 AM
truedefekt's Avatar
Old Jan 18, 2006 | 05:30 AM
forbidden color's Avatar
25 psi with 93 octane is the ecu limit. well, on my car it was.
We've tested this on a dyno.
It'll start mis-firing, as well as limiters start coming in. (fuel cut/boost cut).
Your turbo turns red hot at that moment.
Old Jan 18, 2006 | 05:48 AM
S-1's Avatar
S-1
Originally Posted by truedefekt
kinda the same question but with no other mods except mbc and 93oct what psi is acceptable to turn up to without hurting anything or pull major timing?? i have a boost guage and my 03 8 keeps a steady 20psi at full boost which i think is odd but falls about 16-17psi after 6300rpm.. i was thinking of possibly just 1psi more wouldnt hurt too much am I wrong ?
Every car reacts a bit differently! The only way to really know what is acceptable is to hook up a wideband and check your a/f ratio throughout your rpm range. If hooking up a wideband and reading the a/f data is too time consuming, you can always hook up an exhaust temp. gauge to see if things are getting too hot.
But one would think that 1 psi higher wouldn't be detrimental.
