ecu reset
Old Jan 19, 2006 | 10:42 AM
Evo VIII 4G63's Avatar
ecu reset after tbe exhaust install
after installing a turbo back exhaust are you supposed to reset the ecu to see any gains
Old Jan 19, 2006 | 10:53 AM
mump's Avatar
you should reset it so it can readjust itself.
Old Jan 19, 2006 | 12:15 PM
btuneallen's Avatar
Just unplug the (+) side of the battery and let it sit for a few minutes. After plugging the battery cable back in, make sure you start the car up and let it idle for a few minutes.
Old Jan 19, 2006 | 12:58 PM
walkedu's Avatar
Be careful not to have jewlery on when messing with batteries. My buddy got some good burn marks on his wrist from his watch touching the positive! AHAHAHA... loser
Old Jan 20, 2006 | 04:41 PM
gklasse's Avatar
+ or -
Is this right?
I thought the proper procedure for disconnecting a battery was to start by disconnecting the negative (-) first?
geo
Old Jan 20, 2006 | 04:44 PM
EVOLVEU's Avatar
yup, neg will work.
Old Jan 20, 2006 | 04:45 PM
ex-honda's Avatar
It's the negative post not the positive. Actually you really don't have to do anything. The ecu will read all the parameters and re-adjust. Not reall a "big" bolt on. But I would do it anyway.....it won't hurt.
