5th gear grind?
Old Jan 25, 2006 | 08:50 PM
Big Shooter's Avatar
5th gear grind?
my 5th gear grinds everytime i go into it now. but if i let it drop to 1000rpm then put it in i doesnt. does this mean a bad syncro? or just a bad gear? what are the chances mitsu will cover a new syncro considering i have an ACT & prostreet flywheel in? but those are my only mods
Old Jan 25, 2006 | 08:54 PM
Warrtalon's Avatar
Like we have said in the other 1000 synchro threads, it depends on the dealer, but there is a TSB for it, so they should fix it for free as long as your car is still under warranty.
I don't feel like getting the link to my TSB threads, so I'll let you use this as an opportunity to practice using the Advanced Search.
Old Jan 25, 2006 | 09:12 PM
evolusion's Avatar
some dealers do some dont.
Old Jan 25, 2006 | 09:23 PM
DizeLLx's Avatar
i had the same problem my 5th gear would grind whn i switched i higher rpm>S from 4th to 5th , the dlr fixed but were diks about it
