How many people use Gravel Mode (ACD) in Rain?
Old Jan 30, 2006 | 05:00 AM
  #46
Nosaj$$MR's Avatar
same here, i use it but do not feel much of a difference
Old Jan 30, 2006 | 12:27 PM
  #47
get faster's Avatar
I dont think we're supposed to 'feel' the difference at normal speeds. Keep in mind your car was designed with wrc in mind. If you're seen it in action then you know why the wet/dry, etc option is included.
if you really want to feel how it works ... on second thought I wont suggest anything. Just know that it works. Always drive carefully, more so when on the roads, in any weather.
Old Jan 30, 2006 | 02:05 PM
  #48
jred321's Avatar
i do when i'm driving a bit more spirited when it's rainy, more as a safety measure than an i actually notice a difference measure. i've played around quite a bit and in snow when it's easy to lose traction it's easy to notice the difference between all 3 modes, snow being the best for actually driving where you want to go safely, tarmac being the most fun
Old Jan 30, 2006 | 02:28 PM
  #49
SOLO2M3's Avatar
Moderate rain on a 65+ second autocross course on sealed asphalt. Tires were 245/35/18 Kumho V710's.
First run was 63+ seconds using the tarmac setting.
2nd run was 60+ seconds using the gravel setting.
3+ second improvement. I did not really feel any difference but i just went faster.
In other words, it really works. (And I won the class)
Old Jan 30, 2006 | 02:35 PM
  #50
GPTourer's Avatar
I use it in the rain and never noticed if it was helping until the other night when I pressed it while accelerating in the rain. I did feel something, a small thud I guess, so at least I know it controls more then that little green light on the dash.
Old Jan 30, 2006 | 02:47 PM
  #51
MREvo-bin's Avatar
i use gravel mode when its raining. i noticed that the rear wheels get dirtier compared to the front each time i use it.
Old Jan 30, 2006 | 02:50 PM
  #52
lvNVevo's Avatar
used once in the snow. I had my Advants on so it was like driving on ice even with the ACD on snow. I used the gravel once in the rain and it felt like it was harder to bring the rear end around than on tarmac
Old Jan 30, 2006 | 03:27 PM
  #53
DaWorstPlaya's Avatar
Originally Posted by aberabee
. in tarmac mode, the *** end of the car slides out and i need to countersteer to keep it from spinning out. in gravel and snow mode the car doesnt lose its poise, but accelerates nicely through the huge turn. in the rain or snow the difference is even more notable. while in tarmac i sometimes can feel the wheels spinning and getting traction, whereas the other two settings get me through the turn smoothly (well, as smooth as is possible in snow)
+1 ... you are correct, every subsequent mode after Tarmac, improves stability (induces more understeer) under slippery conditions. Therefore it keeps the car more predictable when road conditions change(you won't notice the difference)... thus making you faster ...
https://www.evolutionm.net/forums/sh...d.php?t=175195
Old Jan 30, 2006 | 03:33 PM
  #54
badbrain's Avatar
I switch it to gravel whenever it rains. Don't notice difference, but I don't corner hard in rain. Come to think of it, I rarely corner hard when it's not raining. I'm not sure why I even bought an Evo.
Old Jan 30, 2006 | 03:41 PM
  #55
an0ther's Avatar
lol
Originally Posted by porque
The ACD won't do anything for hydroplaning. That's simply a function of the tires (most important), car's weight, and your speed.
I can't believe some of you guys never touch the ACD. It's so damn cool, if I had it I'd be switiching to gravel if I saw a couple rocks on the road, for no reason other than to amuse myself.
Old Jan 30, 2006 | 04:19 PM
  #56
WarmPepsi's Avatar
Gravel is the setting designed for wet or loose roads. In this setting, the ACD will delay in freeing the center differential for a moment (possibly 2-3 seconds).
therefore, it'll stay locked a touch longer before opening up on a turn. (more power still to the rear = oversteer)
good link though, i forgot it was on here
Old Jan 30, 2006 | 04:21 PM
  #57
GPTourer's Avatar
Yeah, really. You already get more understeer under poor traction conditions.
Old Jan 30, 2006 | 04:45 PM
  #58
DrSmile's Avatar
I'm too tired to do a physics project, but I have noticed it is easier to spin the car in gravel and snow mode. I definitely think you get more oversteer, not understeer.
Old Jan 30, 2006 | 05:20 PM
  #59
donmeca2020's Avatar
yea i usually change it to gravel while driving on wet roads. i dont really see too much of a difference.
  #60
Rnm's Avatar
Rnm
I don't change it period.
