puttin cams but ..
Old Jan 30, 2006 | 08:28 AM
Dead-Man Inc's Avatar
puttin cams but ..
the cams are on the way ... 264 intake and 272 exhaust ....
but at the mean time i am selling my MBC ...
so if i recieve the cams .. is it ok to install em? while i dont have a Boost Controller on my ride .. and then getting a flash ...
also i am recieving a Walbro fuel pump and ARP headstuds ...
gonna sell my MBC cuz i am plannin on gettin an EBC .. so im saving up ...
Old Jan 30, 2006 | 08:52 AM
4TUN8's Avatar
I would get a tune asap. I think the car is going to run kinda crappy with cams on no tune.
Personally I would stick with the MBC vs the EBC...less hassle and the MBC will hold the boost better in most cases.
Old Jan 30, 2006 | 09:28 AM
i am gonna get it tuned .. after installing the cams ..
i hardly drive the evo ... i got another ride .. so i'll just install the cams, and park it in the garage ..
Old Jan 30, 2006 | 09:38 AM
Soon2BEVO's Avatar
Id also just stick with the MBC. Easy, cheap, effective. You CAN drive the car with the cams in it untuned, but I really wouldnt boost much with them, esp WOT. I had my cams installed at Pruven and while I was waiting for my tune (Al was coming at 1pm, they finished the cams at noon), I asked to go get some food, they said it was fine, just dont beat on it!
GTSMWET's Avatar
+1 to that keep the MBC, no need for the EBC
Old Jan 30, 2006 | 09:42 AM
bdking57's Avatar
I definately like my AVCR vs my old in cockpit hallman boost controller.. especially in autox, in lower gears I can dial in the EBC to hit higher boost levels.. plus running two maps that you can switch in a second is very nice... let not forget valet mode. It also doubles as a boost gauge.. so with the mbc, your going to need boost gauge + mbc.. vs just the ebc.. the ebc is actually cheaper and your getting alot more options.
Old Jan 30, 2006 | 09:48 AM
lbcevo's Avatar
Is it possible to use the MBC to set the upper limit in case the EBC fails? So you set the MBC at like 25 psi and let the EBC control boost from 22-25 psi depending on the octane your using.
Old Jan 30, 2006 | 09:52 AM
bump ..
i still didnt get my answer .. if i could install Cams on the ride with no BC ...
thanx anywayz everyone for ur opinions ...
it's just when i installed my IC pipping the garage worked on many evos and told me MBC is no good on evos and better get EBC ..
Old Jan 30, 2006 | 10:07 AM
bd307's Avatar
You should go to another shop for your things if they said MBC is bad for Evo's.
Old Jan 30, 2006 | 10:10 AM
lbcevo's Avatar
Yes you don't need a BC for cams. They won't raise the boost as far as I know. Wasn't a problem for me. Do you have a boost gauge?
Old Jan 30, 2006 | 11:59 AM
yes i do .. but it's not equiped
Old Jan 30, 2006 | 12:14 PM
get faster's Avatar
You dont have to install the cams and boost controller at the same time. Lemme ask, how does your car run with the intake and no flash?
Old Jan 30, 2006 | 09:59 PM
it runs fine.. with no problems ..
Old Jan 30, 2006 | 11:33 PM
Jakeg97's Avatar
Originally Posted by Dead-Man Inc
bump ..
yes , you can install cams with no bc
but i read that al prefers having an bc when he does a street tune
so its ok and probably better to have one
Old Jan 30, 2006 | 11:37 PM
Jakeg97's Avatar
i know of 5 evos that run an intake with no flash and they are just fine. of course you can get more power with a tune
