Transmission noise.
Old Jan 31, 2006 | 01:31 PM
SLW EVO's Avatar
Transmission noise.
Well i just came back from my 1 month long vacation. started up the evo.. and it just barely turned over (forgot to take off the - battery terminal).. anywho.. now, when i drive it, it makes a whining/humming noise right at round 2.5k rpm's in 3rd, 4th, and 5th gear.. while the clutch is fully let out and cruzing at the low RPM.. i have an exedy twin plate clutch and flywheel.. just fyi.. any ideas as to what it could be? i already checked the tranny and diff fluids and they are fine.. also the car/transmission feels fine under boost and driving.. the sound is just friggin annoying!
if you have any idea as to what it could be.. let me know
thanks
Old Jan 31, 2006 | 02:07 PM
Ph3n1x's Avatar
I have no idea. I have NEVER searched or read about this symptom. Maybe the supercharger needs oil.
Old Jan 31, 2006 | 02:32 PM
construct1's Avatar
could be the tranfer case, mine whines also but i have 43 k on mine with the stock clutch setup, but the tc has been know to be a weak spot also, have a mitsu tech or garage check to see if they now where the noise is coming from trans or tc
Old Jan 31, 2006 | 03:24 PM
ashton13's Avatar
You just took a month long vacation so im not talking to you...
Old Jan 31, 2006 | 03:30 PM
evo racing's Avatar
i have a whine too...is it loud enough so that when ur radio is turned up pretty high, its still heard?
Old Jan 31, 2006 | 04:06 PM
Alias's Avatar
Your evo have a supercharger???
Old Jan 31, 2006 | 04:10 PM
Ludikraut's Avatar
thanks
I also have an Exedy Twin, and it also makes noise in all gears. I wouldn't worry about it too much, but it never hurts to change your tranny fluids a bit earlier than the service schedule ( diaqueen in the TC and rear diff, BG Synchroshift II in the tranny).
l8r)
Old Jan 31, 2006 | 04:31 PM
fsugatorbait's Avatar
Hilarious!
Im pretty sure he's being sarcastic because this topic has been beatin more times than Tyson.
Old Jan 31, 2006 | 05:08 PM
400awhp16g's Avatar
It only makes that noise when like coming to a stop sign or red light when i put in first with the cluth fully depressed while moving.. i also have exedy twin disk
Old Feb 2, 2006 | 09:32 AM
SLW EVO's Avatar
thanks.. to most of you.. i had the t-case fluid changed.. diaqueen fluid..have redline full synthetic in the tranny and diff.. changed less than 2k miles ago.. still makes the noise.. car feels strong still.. i'm thinking maybe the left front wheel bearing? what does anyone think about that?
i doubt that's the problem.. but im just trying to make some sense of waht's going on.. i figure it COULD be the transmission.. but i just had the fluid changed! anyway let me know
Old Feb 2, 2006 | 09:56 AM
STi(m)'s Avatar
Sounds normal to me. My transmission also whines in gear with the clutch fully depressed. I wouldn't worry about it. My friends 03 EVO whines through first and second.
Old Feb 2, 2006 | 10:07 AM
EVO-Lust-VIII's Avatar
My car whines and the gears growl with reverse torch (when wheels put power to the engine) and I only have 5k miles on mine with a stock clutch (and stock everything). But I had a mechanic take a spin in the car and he said it's just normal "gear growl".
At first I was convinced it sounded worse after my first oil change (2,500k) but then I realized that as the engine breaks in... it seems to get a bit louder. I think the oil change was just a coincidence. After about 3k... the car started to sound more like a Mustang than a ricer. But I guess that's just how it is.
Old Feb 2, 2006 | 10:09 AM
Ludikraut's Avatar
Food for thought: when I had redline in my rear diff it didn't last much longer than 2K.
However, as I said before, the Twin does seem to make more noise in all gears and especially when decelerating.
l8r)
