greddy boost controller
Old Jan 31, 2006 | 04:02 PM
IXmr321's Avatar
is anyone using the gredy profec spec-II boost controller? i just got mine and im wondering about what percent to set it at for my high boost to be 21-22 psi...?
Old Jan 31, 2006 | 04:08 PM
bluebanana23's Avatar
it all depends on what mods you have but then again you have a 9. Mine is at 43% with a full exhaust wityh o2, intake and I/C pipes. I would start yours at the low 30's and go from there. Keep in about the weather differences.
Old Jan 31, 2006 | 04:09 PM
IXmr321's Avatar
o sorry hks intake, downpipe, and exhaust
Old Jan 31, 2006 | 04:35 PM
fsugatorbait's Avatar
Old Jan 31, 2006 | 07:57 PM
IXmr321's Avatar
ok next question.....what is the highest but still safe amount of boost to run on a stock fuel pump(i know, im changing it next week) but until then is 21-22 ok?
Old Feb 1, 2006 | 11:27 AM
IXmr321's Avatar
thanks for all the help....
Old Feb 1, 2006 | 11:32 AM
4TUN8's Avatar
We have a wonderful search feature where all of your questions will be answered. Check it out.
I will save you some trouble though. The fuel pump in the IX is better then the fuel pump in the VIII (supposedly). I would be less concerned with getting a fuel pump and more concerned with getting the car properly tuned. If you plan on doing more modification, then I suggest getting the fuel pump and THEN getting the tune.
Topics of safe boost levels for stock parts are covered a million times here. It's also debated quite often. If you're running 91 octane I wouldn't suggest higher then stock boost levels, if you're running 93, maybe you could get away with an extra PSI or so, but again, I don't know because the car isn't properly tuned.
IMO stay at stock boost levels until the car is tuned.
Old Feb 1, 2006 | 11:37 AM
Ph3n1x's Avatar
Why couldn't you jsut answer the damn question....than type all of that.
Dude shouldn't go about 20psi on stock pump, pretty sure.
Old Feb 1, 2006 | 11:53 AM
IXmr321's Avatar
i did the search but like you said it has been debated several times with no real clear answer thats why i ask straight forward...what is safe? i plan on getting a pump next week and a dyno tune asap
Old Feb 2, 2006 | 04:50 AM
4TUN8's Avatar
To the above 2 posters, I did answer both questions. On 91 octane "I" personally wouldn't go above stock boost pressures, which is around 20 without a tune, on 93 I wouldn't go further then 21-22 without a tune.
The tune is key, but I've already answered that.
