DP and check engine
Old Feb 5, 2006 | 08:24 PM
lukytry's Avatar
DP and check engine
Is there any other alternative to removing the cel, besides splicing into the ecu wire??
Old Feb 5, 2006 | 08:28 PM
brettla's Avatar
you could try the spark plug non-fouler cel fix
Old Feb 5, 2006 | 08:36 PM
Ultimate CC's Avatar
+1 to that, just make sure you don't have the 02 sensor rubbing under the car otherwise you will blow your engine fuse, very common problem thats easily fixed
Old Feb 6, 2006 | 02:27 AM
Jakeg97's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=114931
Old Feb 6, 2006 | 02:47 AM
Evolved Monkey's Avatar
You can buy one from gruppe-s for 15$ if you want don't want to machine the non-foulers into one piece.
