VIII VS IX Handling on Track?
Originally Posted by zmeli
The inside rear wheel will lift during hard cornering. you can see this at the Streets of willow going thru the skidpad section of the track. Volkswagons were notorious for this (in the 80's) the GTI"s were fun to watch lifting that rear wheel on every corner.
Since the USDM does not have AYC I wondered if the US cars had the lower stiffer rears installed. I looked at the IX and the rear seems noticably lower?
track junkie
I'm a track junkie. On my 05' GSR I replaced the springs with Tanabe GF210's and put a Hotchkiss rear bar on (lightest setting). I dialed in one degree of negative camber all around with zero toe all around. From a handling perspective, the car is a beast on the track with these cheap ($300) mods. Much, much, much better than stock. Very little roll, very little understeer and very controlable.
