bad day at the track!!!!!!!!
Originally Posted by NIGHTMARE
I dont understand how the typhoon intake could mess up anything. Someones gonna have to expain that one to me.
What if someone had a mini battery and they couldn't use the stock air box anymore? Then what? Is the cone filter from Buschur a "better" kind of intake than to get the whole K & N intake?
What does a mini battery have to do with the stock air box? It's smaller than the factory battery there should no clearance issues.
From what I remeber it's more an issue with open element filters and the turbulence they cause than the hard pipe. The turbulence confuses the MAF and throws the reading off.
If you HAVE to go to some type of open element filter (as in not just want to because you like the noise) there is a good chance you are making some serious power and should either be tuned to deal with it or have gone to a speed density set up already. I don't know if the open element filter in some type of induction box work any better than ones that are just sitting open in the engine bay.
They're smaller overall, but they're usually turned 90-degrees and are so long that they interfere with the stock airbox.
So if you're tuned for it then it doesn't matter right? Like from dynoflash?
That would make sense so, they provide clearance for IC piping. I thought that most that fit in the tray though.
As I'm leading us further off topic.
The reason I asked was cuz I just got my mini battery and it said it will not fit the stock air box. It came with it's own tray. I really didn't believe them so I looked in my engine compartment and see if I could fandango something around you know? But no. You can't. It's just too long.
You could relocate it to the trunk. It help out the weight bias and free up all kinds of room in the engine bay.
I just don't get the appeal of an aftermarket intake on a turbocharged car. Maybe, since it yields decent gains if paired with the appropriate exhaust in a naturally aspirated application, people new to turbocharged cars just assume if "A" then "B". For the money spent on an intake you could have bought a Walbro 255, or a stiffer rear sway bar, or a very nice MBC, or even a pair of decent 6x9 speakers. In terms of "bang for the buck", an aftermarket intake has got to be at the bottom of the list. The best arguments "for intakes" usually consist of space saving issues and visual appeal. As a performance mod they are, at best, miniscule IMHO. Let the flaming begin.
all these things are new to me for the evo! second this is not my first turbo car i have had a srt-4, mazdaspeed protege,turbo h23 prelude,and a wrx all had intakes on them but did not run into problems like the evo, im not being **** or anything but you guys that have been owning them for a long time know more than some of us who have not,so the whole thing is to get info not to be flamed....we are here to help each other right? as for my mods i have a fuel pump on the way,hallman mbc,and will be getting a flash from turbo trix
,flame on
