bald tire question
Old Mar 3, 2006 | 12:57 AM
J8dailo's Avatar
bald tire question
i have 3 good condition tire and one really bald driver side tires... what could have cause this? i want to know if there is something causing it before i get new tires.. my buddy told me it could be an bent control arm
pic here
Old Mar 3, 2006 | 12:58 AM
J8dailo's Avatar
the tire looks like it could blow any second because the tread on the edge is so thin
Old Mar 3, 2006 | 01:39 AM
bolsen's Avatar
100$ says alignment.
Here's what I get for not having proper alignment
Old Mar 3, 2006 | 04:11 AM
honda-guy's Avatar
take it to the shop and get it align. stock evo have negative camber and the tires usually have a premature wear on the inside but yours looks like it wore on the out side. could be a bad toe problem.
Old Mar 3, 2006 | 07:43 AM
aklucsarits's Avatar
It's possible that it could be a bent control arm, especially since it looks like the outside is what is worn. But it's also possible that your alignment is just out of whack. Either way, the way to check is to get a 4 wheel alignment done, and you need to do that before driving on your new replacement tires anyway. The alignment tech should be able to tell right away if something is bent because it will not align properly.
Old Mar 3, 2006 | 08:30 AM
BuLocal's Avatar
I agree, two options not listed on the window sticker of the Evo are bad allignment and worse paint.
Old Mar 3, 2006 | 10:27 AM
bullfrg's Avatar
Mine looked exactly like that and it was from the bad factory alignment. Luckily, my outside edge also looked like that from autox so no big deal for me.
Old Mar 3, 2006 | 11:28 AM
mathgeek's Avatar
Same thing happened to me. The toe was off from the factory. I had the car realigned when I replaced the tires. I now have 12,000 miles on the new tires and they're wearing perfectly even. I wish I had done that when the stock Advans were new.
Old Mar 3, 2006 | 02:38 PM
el producto's Avatar
HAHA YEA RIGHT both my inside treads of the front Advans are totally toast. and the drivers side one is so bad it has a rip and I can pull string from it.
I'll post pics on this tomorrow of them since i Got new shoes and rubba.
P.S. Have ridden 17,000 miles on advans.
Old Mar 3, 2006 | 02:46 PM
WRXEM's Avatar
I vote for alignment and tire pressure
Old Mar 3, 2006 | 02:50 PM
Greg K's Avatar
get it aligned, ballasted for driver weight. it will make a difference, outer edges usually indicates a toe problem, also I doubt you have a bent control arm, the evo arms are cast and castings usually break rather than bend.
Old Mar 3, 2006 | 03:32 PM
sonicnofadz's Avatar
Would the difference in tire diameters have damaged the center differential?
Old Mar 3, 2006 | 08:45 PM
J8dailo's Avatar
im only 145 lbs so my weight couldn't be a problem..im going to get new tires and get it aligned..i wish i wouldve knew that evo was misaligned from the factory..
i did went to an shop before about my alignment because i was getting really bad ride..but they said my alignment was perfect so i discregard it...
Old Mar 3, 2006 | 08:52 PM
GroundChuck's Avatar
I just got my 03 aligned at the mitsu shop for $99. I wish I would have done it earlier (55K miles now). My tires looked like Bolsen's before I got my new ones. Hopefully the alignment was the issue.
Old Mar 3, 2006 | 09:00 PM
Evoryder's Avatar
bad or no alignment...get one done asap right after you mount n' balance your new tires
