What order should I do these mods
Old Mar 7, 2006 | 07:51 AM
dsldsl25's Avatar
Well I have a long term vision in mind of these mods and would like to know which order I should do them in. I can not spend all the money up front and just do them all, but I plan on doing them over the next 1 to 2 years. Any advice on what I should get and when would be greatly appreciated. The main reason I am asking is I don't want to waste money on flashes and such that I don't need to. Also If you think I need any other supporting mods please let me know. I will probably buy many used parts to do these upgrades.
Long Term Goal:
Header, DP, Cat Delete, Catback
K&N Filter
MBC (Which one?)
Flash (dyno or mailin from who?)
Cams
Fuel Pump
ACT Clutch/fly wheel
Thanks for your 2 cents
Old Mar 7, 2006 | 08:06 AM
06MR's Avatar
Start with the Warrtalon/Buschur package
- buschur turboback(dp, cat delete, cat back)
- Forge MBC
- Dynoflash
Old Mar 7, 2006 | 08:14 AM
evo150's Avatar
if you cant afford the buschur turboback yet, start with the dynoflash and mbc. but the warrtalon package is a really good starting point
Old Mar 7, 2006 | 08:15 AM
Warrtalon's Avatar
Do all that over 2 years? That might be tough, but this is the order you should follow:
- Boost gauge
- Filter
- MBC (Forge UNOS, of course)
- Fuel pump
*MAIL-IN DYNOFLASH*
- cat-back
- test pipe
- downpipe
*MAIL-IN DYNOFLASH*
- header
- cams
*CUSTOM DYNOFLASH*
- Clutch way later after 2 years or so on the stock clutch
Old Mar 7, 2006 | 08:25 AM
HassounEVO's Avatar
1st-I would do the Flash and K&N at the same time, I have a WORKS P2 and i love it!! Very safe and smooth, and you can have them set it for your desired boost. My mods are in my sig, i boost 25>22 PSI with no MBC.
2nd- I would do a whole turbo back, you don't really need the header just DP, Cat delete, and catback to start. If you have to have a header, check out BUSCHUR ported and coated stock manifold. Amazing piece + no cracking!
3rd- Do your cams and fuel pump, VERY NOTICABLE power with cams, they're great!!!
All of my mods in my sig were done within 3 months , i wish i had your patience, you could save a lot of money going used...
Old Mar 7, 2006 | 08:28 AM
Warrtalon's Avatar
I would not recommend waiting on the fuel pump that long.
I also would not pay attention to him saying he runs 25psi, because he runs 100oct all the time.
I also would not recommend an expensive Works flash, because you can't get free reflashes unless you get all your mods from them, which are ridiculously expensive.
Old Mar 7, 2006 | 08:41 AM
HassounEVO's Avatar
Man, This is why i don't post too much
I wasn't telling him to run 25 PSI. I was simply saying that i run 25 PSI with NO MBC...
And why would he need a fuel pump with only Filter, Flash, and TBE?? I understand it's insurance, but he doesn't NEED one for those mods without cams, especially if modding slowly and on a budget the way he wants to do it.... My 2 cents, that's all he asked for....
Old Mar 7, 2006 | 08:46 AM
Warrtalon's Avatar
You failed to mention the 100oct, which is not a good idea. You need to also mention that when saying you run 25psi so that newbies don't get the wrong idea.
The fuel pump is exactly that - insurance. We've had enough rod bearing failures recently that it makes no sense to get flashed without at least installing an $85 fuel pump. Especially in your situation running 25psi - that's why you need the pump, not because of the cams. If he's modding on a budget, why would you suggest anything from Works to begin with, though?
Old Mar 7, 2006 | 09:14 AM
RobDogg's Avatar
owned
Old Mar 7, 2006 | 05:44 PM
dsldsl25's Avatar
Thanks for the thoughts, I have ordered my Catback for $300 shipped I already have K&N and I will do the Mail in Flash, Pump, and MBC after my first couple AutoX events this year. I would like a small chance to compete and the MBC/Flash would not allow that unless I stick like $5g more into my car which I am not planning on doing.
Do you all recommend the flash over a piggy back?
Old Mar 7, 2006 | 06:07 PM
Ph3n1x's Avatar
Why would you advice a MBC and not a Fuel pump?
Noobs will want to turn that boost up and will just get anotehr "I blew my engine thread"
Old Mar 7, 2006 | 06:09 PM
Warrtalon's Avatar
Yeah, go have fun in STU if you can, because that's better for us than A-stock. Then, you can do the MBC and other stuff but still be in BSP, which isn't quite as bad as SM, but still pretty rough, heh.
Old Mar 7, 2006 | 06:10 PM
Ph3n1x's Avatar
Originally Posted by RobDogg
owned
Stop kissing ***, Warr was just explaing himself...
Old Mar 7, 2006 | 09:39 PM
BOOSTEZ's Avatar
A fuel pump is definitely insurance. I will agree with that. However, I don't think it HAS to be the top priority for minimal mods. If I only had $85.00 to spend on a bone stock evo, it wouldn't be a fuel pump.. rather, a MBC.
But I hear you about the pump.. I just don't think it will start to be a factor until you are over 300awhp.
-M
Old Mar 8, 2006 | 01:21 AM
Jakeg97's Avatar
Long Term Goal:
Header, DP, Cat Delete, Catback - 1.
K&N Filter - 2.
MBC (Which one?) - 3.
Flash (dyno or mailin from who?) - 4.
Cams - 5.
Fuel Pump -6.
ACT Clutch/fly wheel -7.
order
1.
3. hallman
2.
6.
5.
4. dynoflash
7.
