A quick question...
Old Mar 7, 2006 | 09:34 AM
heSOshAdy's Avatar
A quick question...
Last night someone stole my Shorty Antennae off my car. Whoever took it had a hard time twisting it off and instead snapped it. The "screw" part of the antennae is stuck inside. Is there any way to get this out?
Thanks in advanced.
Richard
Old Mar 7, 2006 | 09:37 AM
slow_evo's Avatar
Can you drill a hole in it and get it out like that? Or what about about with pliers? Is there anywhere on it that you can get ahold of it?
Old Mar 7, 2006 | 09:38 AM
AndyBandy's Avatar
drill it out first then see what you can do from there.
Old Mar 7, 2006 | 09:45 AM
evozakk's Avatar
thats some bull ****, is it down inside or can you grab it? if not your gonna have to drill it
Old Mar 7, 2006 | 09:48 AM
rcheung's Avatar
That can be tough If you can drill a small hole in there you can use a screw extractor and it will come right out. The hard part is drilling the hole.
Old Mar 7, 2006 | 09:55 AM
NoTec's Avatar
THis is true. Very true. Just take your time when you drill the hole. And before you start, I would cover the entire area around the antenna with that blue painters tape just to prevent any scrathes from the shavings. Goodluck
Old Mar 7, 2006 | 09:59 AM
Links0000's Avatar
Mebe try getting a little pick and try pushing against it at an angle to turn it. Even try tapping the pick with a hammer to turn it. If this doesnt work then yes like everyone else said a pick!
Old Mar 7, 2006 | 10:07 AM
MisterMR's Avatar
How about using a dremel to cut a shallow slot into the top of it and then using a flat-head screwdriver to unscrew it?
Old Mar 7, 2006 | 10:11 AM
WrX Kila's Avatar
Go to a Honda dealership and get a new one... of the s2000 i believe.
