bg syncroshift
Old Mar 10, 2006 | 03:32 PM
Danny23's Avatar
i didnt mean (syncro shift eleven just typed wrong).And it doesnt say it on the bottle just syncro shift and under it it says for front wheel drive manual trasmissions
Old Mar 10, 2006 | 06:53 PM
Mookie's Avatar
Lancer shop has it
Old Mar 10, 2006 | 08:16 PM
Danny23's Avatar
i put the bg in about an hour ago. last week i took the res. pill out and put in a ss line. the clutch felt ten times better and the trans shifted smoother. I had no complaints at all in the shifting department from new it just got better with the upgrades . the car shifted smooth as glass up, down shifting in any gear or gears so i really didnt think i would feel much if any a difference in the transmission or the shifting from the BG syncroshift but i cant believe the difference. It now shifts much smoother and precise. i took it for a little spirited jaunt and a little easy backroad driving doing a lot of up and downshifting and the difference is truely like day aqnd night. Put this stuff in your EVO guys and girls.
Old Mar 10, 2006 | 08:19 PM
KazzEvo8's Avatar
Lancershop does not have the BG Synchroshift II
Old Mar 11, 2006 | 04:59 AM
GreddyEvo's Avatar
I have done the clutch line with restrictor removal, but if you want just alittle more get the underhood shifter bushings. They take more play out of the shifter and for $30 bucks why not. I got the brass ones from speed source, took about 15 min to get them in. Didnt mean to jump on you about the "11" thing. I am currently using the synthetic in mine and everything feels smooth.
Old Mar 11, 2006 | 12:03 PM
mdosu's Avatar
I thought we're not suppose to use the BGII?
But anyways...I used BGI, and it feels awesome...but during cold shifts, it's still notchy. But still good stuff.
I'm moving on to Syncromesh next just for a try.
Old Mar 11, 2006 | 12:32 PM
Danny23's Avatar
THE CAR SAT ALL NIGHT WHEN I GOT IN THIS MORNING I DIDNT LET IT WARM UP , WANTED TO SEE HOW IT WOULD SHIFT WHEN COLD. SHIFTED SMOOTH AS GLASS AS IF WERE ALREADY WARMED UP AND GOT EVEN SMOOTHER WHEN WARMED UP. I CANT SEE THIS CAR SHIFTING ANY BETTER WITH ANY OTHER TRANS. FLUID, WOULDNT EVEN CONSIDER TRYING ANYTHING ELSE. I USED REDLINE IN MY 03 AND THE bg IS TEN TIMES BETTER. I,M NOT KNOCKING ANY OTHER FLUID OUT THERE I JUST FOUND SOMETHING THAT WORKS FANTASTIC AND I,M STICKING TO IT. YOUR DEFINETELY RIGHT ABOUT THE SHIFTER BUSHINGS I HAD A bm short shifter with the metal bushings on the shifter and under hood and it was like day and night. nice and stiff with rifle bolt accuracy, will probably be doing it to my IX in the near future. and as far as the eleven comment dont sweat it brother no big deal i would,ve said the samething
Old Mar 11, 2006 | 12:45 PM
WrX Kila's Avatar
I need to change my rear diff oil, never did .. 42000miles.
Old Mar 11, 2006 | 03:52 PM
dcvolki's Avatar
I got my BG Syncroshift II from Mach V....well they r local to me but u guys can order from their website or call them...
www.machevo.com
Old Mar 23, 2006 | 07:51 PM
SpoonEvo's Avatar
http://www.slowboyracing.com/shop.php?sid=&cat=838
Maybe this will help.
Anyone in northern jersey wanna split a case of bg?
Old Mar 23, 2006 | 08:29 PM
Evolved Monkey's Avatar
I just got 3 bottles of BG synchoshift from buschur's site for $33 shipped. I wonder why lancershop charges so much more...
Old Mar 23, 2006 | 09:04 PM
Danny23's Avatar
I Put In The Speed Source Brass Underhood Bushings A Week Ago And It Shifts Even Better Now. Next The Bm Short Shifter(adj.)with The Aluminum Bushings Like I Had On My 03 8.
Old Mar 24, 2006 | 06:20 AM
GreddyEvo's Avatar
I will probably never get a short shifter, but let me know how the shifter base bushing feel. I knew the underhood set would help big time, I am just not sure how much additional play can be taken out by switching the base set. I guess at only $30 or $40 bucks why not?
Old Mar 24, 2006 | 07:36 AM
EVO8emUp's Avatar
Mopar ATF + 4 with 1 tube of additive works well also. As afr as I know, you can only get +4 from the dealer.
Old Mar 24, 2006 | 07:53 AM
Doogie Howser's Avatar
Whats the difference btw. bg syncroshift I vs. bg syncroshift II?
