searched, found.. and no luck. (headlights)
Old Mar 27, 2006 | 12:19 AM
lznk41's Avatar
i've searched for "headlight adjustment" and browsed through the main threads including the how-to from n00dle but no such luck. the major threads on headlight adjusting are VERY vague and really frustrating. ok, so here's the breakdown:
I have a set of JDM 8 MR headlights with the cutoff facing incoming traffic (i'm pretty sure all jdm headlights are made this way) and i want to adjust the height level of the HID's (NOT the foglights and NOT the highbeams). WHAT tools are required to turn WHICH gears for just the hid beam? does ANYONE have clear pictures displaying where the gear for the HID's are? (a picture of the tool being used for the hid adjustment would be great)
please DONT tell me to "search" for this topic because im sick of browsing through the threads and not coming up with any answer. ANY help is appreciated. thanks.
-lznk41-
Old Mar 27, 2006 | 12:26 AM
Enyth's Avatar
Bump, as I too am curious about this. I don't have jdm lights, but my car is lowered and I need to adjust my HID's.
Old Mar 27, 2006 | 08:58 AM
brooks1005's Avatar
I have read and tried the adjustment for the HID's but I have a metal piece that blocks the adjustment gears.I need an answer to this too.
Old Mar 27, 2006 | 10:48 PM
lznk41's Avatar
bump
Old Mar 28, 2006 | 02:22 AM
lznk41's Avatar
anyone?
Old Mar 28, 2006 | 08:12 AM
speedjunkie2003's Avatar
wow bud, im sorry, i dont know eather like the guy above i would like to know about this too, NOTE to anyone that wants to lower their car, for example the tein S tech springs will GREATLY lower your headlight range even when from the interion move the adjustment wheel up you still will have a difficult time seeing unless your brights are on.....teins lower the front 1.9 inches and the rear .9 inches.......something to keek in mind....lataa
Old Mar 28, 2006 | 11:04 AM
th3_rEv8lution's Avatar
https://www.evolutionm.net/forums/sh...ad.php?t=75583
Try this. I'm not sure if this is what you are looking foor, but I hope it helps.
Old Mar 29, 2006 | 02:40 AM
lznk41's Avatar
that was the thread i was talking about. none of that information is useful because i believe its for an 03 evo. i have an 05 w/ SSL and jdm mr headlights. anyone got a clue??
Old May 3, 2006 | 08:33 PM
lznk41's Avatar
BUMP
DOES ANYONE KNOW?!?! this is really frustrating me now
Old May 4, 2006 | 12:47 AM
mump's Avatar
in that thread mentioned above, there was a bolt (10mm) that you turned and all the lights would adjust. when i tried to adjust mine, all the lights but the low beams (HIDS) would move because the gearing on the HID adjustment was made of plastic and was stripped. i took the whole light out and looked to see if I could figure something out. there is a metal cable that runs from the HIDS to the bottom of the adjustment gears. what i did was took the whole headlight assembly out, unscrewed the 2 or 3 screws that held the cable in place, put the light back in, adjusted the HIDS by twisting the gear on the end of that cable to where I wanted them, took the light back out to put the cable back where I got it from, then finally put the light back in again. it was a real PITA but in the end my HIDS are where I want them. hope this helps a little.
Old May 4, 2006 | 01:06 AM
Enyth's Avatar
I finally got my headlights fixed and raised. It was a complete b****, but it was worth it. Those pics that n00dle posted are correct. Yes it shows the 10mm on the highbeam, and that is what you need to adjust. You can either use a phillips head, but make sure its a BIG one, or the 10mm socket.
I tried using the phillips head (medium size) and the gears started stripping. In the end, i used the 10mm and it worked fine. The drivers side 10mm started stipping, so i had to use the phillips AND 10mm socket at the same time with a friend.
But yeah, the pics n00dle posted are correct. The pics with the metal plates and what not are incorrect. I, too, have those metal plates, but that doesnt adjust the low-beams. The high beam bolt/plastic gears are pretty easy to see. Hope this helps. I dont have a camera on me to take pics, i'll try to post some later.
BTW, you can adjust them with the lights on which helps a lot. I have an 05 with the SSL and electronic lifter for HIDs. So yea, you have to adjust the high-beam bolt. It's the bolt with the plastic gears running under it, it's pretty easy to spot. Also, rotate clock-wise when you are facing the front of the car and your **** sticking out the front of the car. Also, if you are going to use the phillips head, MAKE SURE YOU TWIST AS FAR AS YOU CAN PER TURN or twist until it clicks, or else itll go back to its original state and start stripping. Start with the phillips head until it starts stripping the gears, if it does strip, then use the 10mm bolt. Hope this helps and good luck
Old Nov 26, 2006 | 01:31 PM
1badgsex's Avatar
that post that noodle posted dont not help!!!! ppl with 05- 06 evos iam in the same situation here and i cant find no help everyone keeps posting that noodle post
lznk41
For Sale - Part Outs
Sep 2, 2016 12:06 AM
lznk41
West Region
Nov 17, 2009 02:12 PM
Kreeker
Jul 12, 2008 12:43 PM
lznk41
Feb 2, 2008 02:06 AM
Boltz.
Oct 27, 2006 06:41 PM
