Boost gauge Q's
Old Mar 28, 2006 | 12:43 PM
Aby@MIL.SPEC's Avatar
Boost gauge Q's
I am thinking about buying a different boost gauge & i am considering the vdo package from 42draftdesign.
However, i dont like the gauge that goes -30hg / 25psi, I prefer the 0-30 psi gauge. If boost does spike above 25psi, i dont want the gauge to get damaged either.
I would appreciate any insight on why i should get a gauge that shows me vacuum, as i am not too concerned about vacuum? Maybe i am missing something???
all insight would be appreciated.
Thanks
Old Mar 28, 2006 | 12:46 PM
dan628's Avatar
well the car idles at about 20 in-hg vacuum, and mild driving goes from vacuum to boost, so it is something you should have....
Old Mar 28, 2006 | 05:31 PM
Hummm. I understand, but not sure if that alone sells me on getting 1.
Thanks for your input
Old Mar 28, 2006 | 05:37 PM
Links0000's Avatar
Why wouldnt you get one that shows both? You can get an autometer that shows both for like 60 bucks!
Old Mar 28, 2006 | 06:04 PM
shivaswrath's Avatar
because if you have a BOOST LEAK, it'll show up. . .that's why. . .
Old Mar 28, 2006 | 06:21 PM
? Can you explain please.
Please dont take this as me arguing, i am just not following your thinking
Here is why i disagree & my thinking regarding your response:
if your measuring your boost/vacuum reading in the factory location; within the plenum, your gauge reading is observed between the throttle blade & inlet valve. if you take off all the i/c piping & idle the car, you would still get the same vacuum reading.
if your talking about boosting situations @ wide open throttle, you would see less boost with either style gauge, feel the car being slow & hear a louder than normal whooshing sound.
Help me see your points
Thanks again for the input
Old Mar 28, 2006 | 06:23 PM
I like the vdo look, but dont care for the cramped numbers of the vdo gauge that has both.
I am hoping there is a signifcant reason to get the gauge that has both over my visual dislike of it.
vicariousthrill
Dec 22, 2013 12:35 AM
Mr. Move
Dec 25, 2012 03:29 PM
ProPilot04
Aug 29, 2011 09:20 AM
LilJapnBoy
Mar 11, 2004 09:00 AM
alex_alex
Jul 31, 2003 05:38 PM
