Questions About First Oil Change
Old Apr 4, 2006 | 01:21 PM
galvitron's Avatar
There is nothing wrong with changing it at 500 miles, other than the potential for wasting money. Every engine is slightly different, so you can never truly tell without professional equipment. I did mine at 500 and again at 3500. I'll do it again at 6500, then every 3000 after that.
Changing your oil is a cheap, easy way to maintain the engine. So what do you have to lose (besides cash )?
Old Apr 4, 2006 | 01:34 PM
NocturnalEVO's Avatar
I dont' have to do anything special to flush out the metal shavings correct?
Just let the oil drain out, and then pour new oil in?
Old Apr 4, 2006 | 01:38 PM
j3ffw19's Avatar
i changed mine at 1600 miles mobile 1 5w30
Old Apr 4, 2006 | 01:39 PM
Andrew LB's Avatar
You should also change the oil filter and crush washer on the drain plug.
Old Apr 4, 2006 | 01:41 PM
How often does the oil filter need to be replaced? Everytime I do an oil change?
and how often should I change the crush washer? everytime i remove it from the drain plug?
Sorry for all the newb questions, better safe than sorry
Old Apr 4, 2006 | 02:31 PM
THE4TH's Avatar
Originally Posted by Greg K
not true, I had mine sampled at 500 miles and it came back as oil, no unexpected additives or fillers of any kind. they said the metallic particles they saw in the oil were consistant with the breakin of a new engine.
Cool, thanks Greg
Old Apr 4, 2006 | 02:33 PM
Kings Fan's Avatar
Si Senior!
Old Apr 4, 2006 | 02:47 PM
THE4TH's Avatar
I usually use Fram filters, anyone use anything different? Is there anything better?
Old Apr 4, 2006 | 03:41 PM
Rod Munch's Avatar
Fram filters are really cheap quality. (Google "fram sucks.") Go OEM or quality aftermarket.
Old Apr 4, 2006 | 03:46 PM
HIPSI9's Avatar
just had mine done at 1440 miles
Old Apr 4, 2006 | 03:47 PM
dbdude's Avatar
If you want it to be a special oil change and go the whole 9 yards then you got to disconnect the crank angle sensor and crank the engine a couple of times with the drain plug off to completly take out the old oil out of the turbo.
Old Apr 4, 2006 | 03:49 PM
Andrew LB's Avatar
Filters and crush washers need to be replaced every time you change your oil.
Old Apr 4, 2006 | 03:55 PM
Fluid1's Avatar
Did you never work on your VIII????
Old Apr 4, 2006 | 03:59 PM
9g's Avatar
9g
yup. its always better to ask stupid questions than ask it after you've done something wrong.
Old Apr 4, 2006 | 04:08 PM
KINGEVO7's Avatar
there is also a mobile 1 filter.
