Silencer In The Exhaust
Old Apr 6, 2006 | 12:53 PM
Warrtalon's Avatar
Monster, read the whole thread. I said a guy LOST 40whp from using the tail silencer on his TBE. In other words, it's MORE restrictive than the stock exhaust.
Yes, a TBE should give NO LESS than 25whp. It's usually 30whp or more, though.
Old Apr 6, 2006 | 01:06 PM
NYEvoguy's Avatar
Bottom line is that it is not reccommended if you want to keep your power up. Get a quieter exhaust if you don't like how loud your's is. But it's your call. Just make sure your happy with what you do. I personally would not use a silencer.
Old Apr 6, 2006 | 01:15 PM
MonsterEVOO's Avatar
My Mistake... Thanks
Old Apr 6, 2006 | 01:19 PM
bluebyu36's Avatar
no doubt thanks guys
Old May 25, 2010 | 08:56 AM
boczo777's Avatar
well im trying to make my evo lil more quiet too, gotta straight 3in all the way from downpipe, what u think about that???
http://www.thmotorsports.com/vibrant.../i-238629.aspx
http://www.dynomax.com/mufflers.php - ultra flo, looks like pipe inside got same diameter that inlet and outlet pipes so it shouldnt make more back pressure and i know for fact that in my buddy's turbo lexis is300 made it waaaaaaaay more quiet
Old May 25, 2010 | 09:04 AM
boozeup&riot's Avatar
Ok, here's a test:
Run around the block as fast as you can, and then record your time.
now, go grab a coffee straw and use that as your "breathing tube." You can inhale just as you normally would but you can only exhale through the straw. After you have taped it to your face, try to run around the block as fast as you can.
If you don't die, you may notice a distinct difference in your speed/respiration with and without the straw. This is exactly what you're doing to your motor.
All joking aside, resonators, high-flow cat (if you're catless), and experimenting with diff mufflers can all quiet you down.
Old May 25, 2010 | 09:10 AM
boczo777's Avatar
thats my point, diameter is same as pipe, 3inches, and some fiberglass around, nothing stops gas flow
Old May 25, 2010 | 09:13 AM
buchnerj's Avatar
Resonators won't hurt you, silencers will. There is a very noticeable power difference.
Old May 25, 2010 | 10:01 AM
BoostIsMyDrug's Avatar
+1. After I got my new exhaust, I put the silencer in just to see what the difference would be... Drove around the block, parked the car, took the silencer out, and threw it right in the trash.
Old May 25, 2010 | 10:15 AM
EVO196's Avatar
I found a Cobb Exhaust & Megan resonated test pipe, you can't get quiter than that on an Evo at idle, WOT is a different story....
But I did try the Silencer for a while & I was in denial of how slow the car felt.
Silencers are a temp fix.....
Old May 25, 2010 | 10:24 AM
JJsEvo8's Avatar
Someone did a dyno comparison with the silencer and without on these forums. There was a huge power difference. Check out the search button.
Old May 25, 2010 | 11:06 AM
boczo777's Avatar
end of silencer subject, im talking bout resonators now, so now effect on power but what about noise???
Old May 25, 2010 | 01:11 PM
euntaeyi's Avatar
Originally Posted by bluebyu36
relax that buddy, what are the computer police
What are you saying?!
Old May 25, 2010 | 01:28 PM
Engrish translation: "Relax there buddy! Who are you, the computer police?"
Old May 25, 2010 | 01:32 PM
mitsuevodriver's Avatar
Silencer is gonna sound nasty. Hhahha!!
