How Many Miles on your Evo? | [MERGED]
110k VIII daily driver/autox'er.
Bought car with 66k with ACT clutch 2 years ago. Timing at 80k and replaced with Exedy Twin at 90k. Original trans, diff, and tc.
Current on IX turbo, intake, exhaust, mbc, cams, and E-85 = 367hp/362tq on KHC Mustang Dyno.
03 VIII. Im at almost 104k. Had the timing belt and serpentine belt done at 75k. Still on the stock clutch (unless the previous owner happened to have changed it before he traded it in which I feel is unlikely). Only thing that has ever broken on it was a fuse blew after going through a huge puddle in a nasty rain storm. This is my daily driver and occasional auto x car. Most reliable, best car I have ever owned. I bought it with 23k in 06. It was completely stock.
I fully expect it to completely fall apart / break down on the ride home from work today after bragging on its reliability.
I have 108,000 on mine...All original parts,engine/drivetrain/clutch etc...upgraded turbo about 2000 miles ago so clutch just started to slip
109K
Dropped off last week for: 2.3 build & new clutch
Made it to 100k+ after:
2 clutch changes ( killed the first in the first week, second lasted ~60K, third was a quartermaster)
Top end rebuild after spark plug electrode made its way onto/thru/out an exhaust valve??(bad compression and bad oil burn)
3 tire changes
1 water line to throttle body replacement
1 driver side tweeter
1 timing/accessory belt water pump change
And those were just necissary replacements. not counting the other add-ons.
3 tire changes
