people with stewart warner oil pressure gauge
Old Apr 17, 2006 | 12:42 PM
shinnster's Avatar
I just got mine installed today
the needle movement is not smooth. Best way to describe it is that the movement is notchy, kind of like the seconds hand on a watch. It responds well, it just has a jerky movement.
Any clues? is this normal?
Old Apr 17, 2006 | 12:49 PM
tobz's Avatar
Yes, it is normal. I cant remember the term, but it does that so you can read it. It's OK. I watch mine everyday all the time.
Old Apr 17, 2006 | 12:51 PM
EvilBlueEvo8's Avatar
mine does this too. i've tried everything. i even ran a 10 gauge ground to the cylinder head to eliminate interferance. mine still twitches. it reads kind of low too. sometimes it reads like 0-5 psi when idling. i think that is due to crappy pressure senders and the mounting location near the oil filter on the evo. my oil pressure it jumpy too though. boost and egt are fine though.
Old Apr 17, 2006 | 12:53 PM
Tristar's Avatar
I just got VDO gauges installed and my oil pres. gauge has smooth movement. That being said, it must not be the location of the sending unit (by the oil filter).
Old Apr 17, 2006 | 12:55 PM
fsugatorbait's Avatar
If you have your sender mounted in one of the galleys in the block you need to get that looked at. That is extremely low and could be a sign of a serious engine problem.
Old Apr 17, 2006 | 01:02 PM
its been like that since i got the car. oem low oil light never comes on. and it only does it sometimes. its the sender cause one time i tapped it with a scredriver and the gauge read zero for a while
Old Apr 17, 2006 | 02:19 PM
Viciouslord's Avatar
don't ever wait for the oil light to come on, to check your oil.... i check mine at least once a week....
- Vicious
Old Apr 17, 2006 | 02:22 PM
Curt@MrLed's Avatar
Former Vendor
i have the mech, s/w oil press. gauge.. works perfect.
Old Apr 17, 2006 | 02:28 PM
althemean's Avatar
I have the electrical Stewart Warner oil pressure gauge. Thats normal operation for it. I saw a Defi gauge and was surprised at how smooth it was compared to mine. As long as it works though.
Old Apr 17, 2006 | 02:37 PM
- Vicious
so do i. i put 500 miles a week on the car too. never had problems with the oil.
Old Apr 17, 2006 | 03:25 PM
shivaswrath's Avatar
- Vicious
YES EXACTLY, I can't stress this enough, our cars, when driven hard, like most Evo owners do, have a lot of oil blow by, which means you're going to be going through about a quart or half a quart every 5000 miles. . .I check in the MORNING (ie oil has sat overnight, so it can all drip to the bottom of the pan) every week as well. . .
Old Apr 17, 2006 | 03:41 PM
i do agree with checking it often and i also agree with it losing a half quart every 5k miles or so, but i don't find a problem with a lot of blow by. my catch can is usually dry. i guess its a combo of me not driving the car hard and probably (hopefully) a good piston ring seal.
Old Oct 13, 2006 | 08:18 PM
evo150's Avatar
just installed my stewart warner oil pressure gauge and it has the "notchy" movement. all the readings from it seem good other than the notchy movement from the needle. why doesnt the gauge have a smooth reading??
Old Oct 13, 2006 | 10:42 PM
lcakes05's Avatar
my sw oil press. is smooth and not nothy sucks for you guys.
Old Oct 14, 2006 | 11:09 PM
evo150's Avatar
i wish mine was smooth. it reads correct while at idle, but once i press the throttle its all over the place. ive triple checked the install still the same.
