Placing Evo on trailer
Old May 10, 2006 | 09:13 AM
adamhw's Avatar
I'm driving from MI, to FL. I'll be towing my car with a rental truck. Any precautions reccomned. I know the trucks kick up rocks, not sure of good way to protect the car with out causing more damage. Some people mentioned wood to help load/unload. Not sure if neccesary, I'm on stock susp/tire except for rear sway. I'll be on 75 the whole way, so should be decent roads. Thanks for the help.
Old May 10, 2006 | 09:30 AM
kingkyle's Avatar
dont worry... your evo will be fine.... depending on the trailer i might use wood to prop up the ramps to make them "longer" or not as steep. Dont worry about rocks... i pull my Evo with my dually and it has 4 big tires and i dont really have any problems.... just make sure you strap it down tight incase you hit the brakes.
Old May 10, 2006 | 11:13 AM
Stew's Avatar
Bring some wood, strap it down tight, and you'll be a-ok
Old May 10, 2006 | 02:29 PM
chrisw's Avatar
If you are concerned about debris hitting the car, shrink wrap it. Any decent marine store will have shrink wrapping kits large enough for a boat, it should be more than enough for your evo.
