boomslang harness question.
Old May 10, 2006 | 01:12 PM
nongtat's Avatar
the boomslang harness that use on safcII, is that the same harness for zt-2 wideband?
thank you
Old May 10, 2006 | 01:16 PM
ddubb's Avatar
I could be wrong but I believe the boomslang harness is basically just a replica of the stock harness so that you don't have to hack that one up. When connecting my safc2 and boomslang harness just used the wires that it told me needed to be soldered together. I assume if you already have that done and wanted to add the ZT-2 wideband that you could just splice those wires all together. seems that there shouldn't be an issue with it
Old May 10, 2006 | 05:24 PM
trinydex's Avatar
uhm... the only way you can plug in both, is to get both plug and play harnesses and link them up together. otherwise some solder is involved.
