evo 4g63 vs. dsm 4g63
Old May 17, 2006 | 11:50 AM
sirloin1219's Avatar
ive read a couple threads about this, i know the evo 4g63 is a transversed and what not, but other than that is there any performance difference between the two? thanks!
Old May 17, 2006 | 12:19 PM
zgodfathera's Avatar
Lol.....
Old May 17, 2006 | 12:35 PM
jdmevo8313's Avatar
Registered User
Old May 17, 2006 | 12:39 PM
GPTourer's Avatar
Ultimately, no. Once both are built and the only thing left Mitsubishi is the bare head, bare block and crank, they have the same potential.
Evos have always gotten better injectors, better turbos, slightly better cams from the factory.
Old May 17, 2006 | 12:44 PM
shiftdsm E's Avatar
evo transmissions were always a bit better as well, better gearing and more reinforcement. The shorter gearing makes a big difference in acceleration both straight line and out of corners, part of the reason why an evo feels faster than a comparably built dsm
I couldn't even count the number of gsx transfer cases ive heard about blowing out after 300awhp
Old May 17, 2006 | 01:28 PM
mchuang's Avatar
Then we got the magnesium valve cover vs the always leaking dsm one, no crankwalk issues so far, but I think the gen 1 has bigger intake ports
Old May 17, 2006 | 01:42 PM
GPTourer's Avatar
Mmmmm, there are plenty of DSMs over 300whp, that's cake for 1 or 2G. 2G cars are similar to EVO III's not anything majorly different except maybe some of the ratios, but not in strength. 90-91's do have the lesser spline drivetrain, though.
Old May 17, 2006 | 01:44 PM
GPTourer's Avatar
Again, 2G engines are equal to Evo III engines, so they will walk just as much. CW is waaaaaaaay overblown and overplayed.
Old May 17, 2006 | 01:53 PM
wow so there really isnt taht much difference..guess the transmission change is a good thing, are there any negative things that have risen because of the tranverse layout?
Old May 17, 2006 | 02:14 PM
GPTourer's Avatar
I am not sure what you are asking since both engines are tranverse. However they flipped it for better weight distribution. Nothing neagtive has become of that. Except you can't put an EVO VI-IX turbo on a GVR4,DSM or EVO I-III without some fabrication.
Old May 17, 2006 | 02:17 PM
well ok i guess then i get things mixed up. What exactly does it mean to be transversed? and the reason why the engine was flipped was for better weight distrubution?
Old May 17, 2006 | 02:20 PM
So after all thats been posted an EVO 4G63 is way better.... PERIOD
Old May 17, 2006 | 02:22 PM
Jazzie604's Avatar
transverse means it sits sideways in the engine bay. you mean reversed
Old May 17, 2006 | 03:05 PM
GPTourer's Avatar
^Right^ By flipped I meant 180 degrees. More of the engine sits behind the front axle on the Evo IV-IX's then it did on prior versions.
It is a DSM that holds the highest E.T. and trap speed record. PERIOD.
Old May 17, 2006 | 04:03 PM
Evo 4G63 right?
