AC fan wiring how to?
Old May 20, 2006 | 06:12 AM
MrB's Avatar
MrB
I have an 03 evo non running parts car. I also have an eagle summit with a 4g63. I want to use the cooling fan from the evo to use on my summit. I am talking about the AC I am pretty sure. Since all fans are missing besides one, I assume it is the ac fan. It is the fan on the passenger side pushing air.
It has 2 plug connections, both of which fit my 92 dsm harness plug, but will not power up the fan. One plug has 2 wires, the other has a single wire.
How should wire this fan up to work?
My current set up on the eagle basically sends power to the fans I have now when the ignition is on. The fans run constant. I have a small radiator, so it actually works nicely. Only problem is that they can't keep up with the 180deg thermostat I have(temp stays at 190-195).
too bad most parts on an evo aren't direct bolt-ons to dsms
Old May 20, 2006 | 06:20 AM
wingless's Avatar
Sorry I have no useful info to share, but sounds like a cool project!
Old May 23, 2006 | 04:24 PM
MrB's Avatar
MrB
I got it to work. All it took, was a little effort. Cut blue and black wire....solder to one plug...plug it in....duh. Too bad it doesn't seem to pull that much air.
summit with 4g63=daily driver go cart
Alchem1st
Mar 15, 2022 08:47 AM
lghtngyello03
10
Jul 22, 2016 03:26 PM
Babs
Nov 28, 2015 10:18 AM
Thebigjoke1337
Aug 18, 2011 10:28 PM
98autogstspyder
45
May 16, 2009 12:23 AM
