Infinity stock stereo wiring?
I was just trying to install a cd player in my girl's eclipse, and what is up with all of them plugs and wires. I know there is a stock amp under the seat and everything but how do you just bypass that and use the head unit. Anyone with info is greatly needed. Ive installed tons of stereo's but never seen anything like this. Thaks.
Did you buy a harness? This combo harness works for my Evo Infinity system. Not sure bout the Eclipse.
http://www.audioallies.com/GetItem.asp?Item=70%2D7003
i bought a "Harness" from pep boys, but it doesnt come with that din harness. do you or anyone know what the pins are of that din harness? that looks like it would be the right adaptor. Also, do those RCA's go for the rear and front speakers or what?
The RCA jacks on the harness are for Front and Rear speakers, and plug into the back of the headunit. The Din plug connects to the Din plug that you pull out of the stock stereo. The bare wires would be soldered to the wires on the harness that comes with the new headunit. On my Evo, that harness lets me keep the stock amp and subwoofer.
ok cool thanks, the only question i have left is that if there arent enough sets of RCA jacks on the headunit could i just cut off the RCA ends and straight up wire them to the front and rear speaker wires from the headunit. I beleive each RCA jacks are set up with either the prong or the outside prongs being positive or negative but im not sure.
