Walbro Install ?
Old Jun 8, 2006 | 05:30 AM
gsrboi80's Avatar
Walbro Install ?
I was talking with a co-worker. Former DSM owner and tuning guru. He was asking if the EVO guys run power to their walbro's stright from the battery. I told him I never heard anything about it. He said mabey it was just a DSM thing. Anyone have expieience with this?
Old Jun 8, 2006 | 06:05 AM
Cajun Power's Avatar
HELL NO! Just swap the stock pump for the walbro. No special wiring needed. It is a direct replacement. Plug and Play bro.
IMHO- I don't want my fuel pump running when my car is off?!?!?!?!?
Old Jun 8, 2006 | 06:15 AM
blackevo110's Avatar
nothing like 'at just lift ur back seat out n unscrew the panel and pull out the out one n put in the new one. really, really simple mod.
Old Jun 8, 2006 | 06:27 AM
machron1's Avatar
Back in my DSM days I did this to my stocker before I got a Walbro, it's pretty common. You get a little more flow @ the higher voltage straight from the battery. To turn it on, you just run a relay with the signal from the original line.
When I did upgrade to a Walbro, I left it rigged up because hey, even MORE pressure
DSMers are straight up DIY and will do anything if it will give them a little more power, and the cheaper the mod, the better.
I remember tuning my DSM with an S-AFC, EGT temps, and the voltage read from the "blue wire" mod to the S-AFC that gave you the voltage of the O2 sensor...and of course feeling the car pull timing...with seat of the pants tuning, who needs a dyno If I remember correctly, the target was ~1,550F EGT and ~.92V AFR.
Old Jun 8, 2006 | 06:36 AM
VTECH8TR's Avatar
In the DSM days this was done. In the Evo you DO NOT need to do it. Just swap it out with the new Walbro #GSS342 and you are done.
Old Jun 8, 2006 | 07:00 AM
ct9a_mr's Avatar
As a former DSM'er I believe I read on here that the wireing the in EVO's is sufficent so there is no voltage drop causing less fuel like DSM's did.
I guess omeone with a fuel pressure gauge would know for sure though.
Old Jun 8, 2006 | 07:58 AM
Dr. SS's Avatar
i believe bolsen is working on running 14.4 volts or something like that directly to his Walbro pump.... maybe he'll chime in.
