does your evo........
Old Apr 19, 2003 | 10:37 PM
Evoboy88's Avatar
hi guys , riding and driving in my dad's evo, i haev noticed the following, and was curious if ur evos did it
after you push it past about 5 or 6k does it back fire when u let off?(i kno its normal for some cars, but with custom exaust its really noticeable)
when engine braking, in 1st and 2nd gear does it rock back and forth (almost like abs)
when making sharp turns at fast rates of speed does the rear end hop a bit?
and finally have you been able to spin the tires in the wet?
thnx for answers, jus a bit curious about the other lancers out there!
chris
Old Apr 19, 2003 | 10:44 PM
Liandrin11's Avatar
Well, I s'pose I have to answer 'no' to all of your questions. I'm sure I could break traction in the wet if I were really setting out to do it though.
Old Apr 20, 2003 | 09:47 AM
Thwack's Avatar
I've gotten the tail to swing out twice in the rain, both kind of surprised me (1st awd car) it transitions form understeer to oversteer on the throttle lift pretty quickly, i'd never really experienced it before.. once the tail breaks loose though, its pretty easy to keep it sliding with a little throttle...
no to everything else.
Old Apr 20, 2003 | 10:44 AM
2Cool's Avatar
No backfire, except when I hit the rev limiter... and thats with the complete 3" exhaust.
No rock.
No wheel hop, just a nice 4 wheel drift if I am way into it.
I can spin the tires fairly well on the dry, with the boost controller and exhaust, so wet would be easy.
Old Apr 20, 2003 | 11:43 AM
OneEyedJack's Avatar
Re: does your evo........
when you downshift to "engine brake" try letting the clutch out a little smoother.
this should go away
Old Apr 20, 2003 | 12:31 PM
Coolguy949's Avatar
Sound like your dad might be running an atmospheric BOV. Yeah? Could be the aftermarket exhaust too.
Old Apr 20, 2003 | 01:25 PM
Evoboy88's Avatar
kool, thanx for the idea on the bov, actually yea it is atmospheric! .ill try lettin the clutch out smoother to, thnx guys
Old Apr 20, 2003 | 03:38 PM
Coolguy949's Avatar
Yeah, well if he wants to stop the exhaust popping he should lean out the mixture a little or run the BOV recirculating.
Old Apr 20, 2003 | 04:08 PM
evo1's Avatar
Not at all but I have not modified the exhaust, yet. Perhaps someone else with modified exhaust can elaborate further.
No rocking on mine ... braking is always very smooth.
Only if I have more passengers (a lot of excess weight in the car). Otherwise the rear end is very stable.
Dry pavement = not even close. Wet pavement = I have but but definitely not for long ... just a very quick spin and then it hooks up quickly ... then again, I try not to launch hard most of time since it's obviously not good for the car.
Old Apr 21, 2003 | 06:17 PM
Yojimbo's Avatar
I can spin the wheels on dry depending on the surface I'm on. In the wet it's too easy. No to everything else.
Old May 11, 2003 | 03:56 AM
timzcat's Avatar
Exhaust backfire could be an exhaust leak which introduces fresh air into the hot exhaust gases and ignites with any unburned fuel.
Old May 11, 2003 | 05:47 AM
hornet's Avatar
I've spun the wheels on wet pavement but non of the other things have happened.
