I need some help, on wiring for IX
I did some searching on hooking up a type 1 HKS timer, but I can not find the correct threads for the IX wiring diagram.
My question is, are what are the correct pin locations for the speed and rpm signals?
I keep finding the XIII wiring diagrams, but the plugs are completely different on the ecm's. The IX has 3 connectors, and the XIII has 4.
Have any of you guys wired one of these in yet? If so help a brother out
https://www.evolutionm.net/forums/sh...wiring+diagram
There is a diagram in there...I don't know if it still works. i can't pull it up on my work comp. Anyway i used that diagram to install my Apexi TT. Some of the wires on the diagram doesn't match up to the pins...I just guessed a couple.
I tried 9 wiring, 9 ecu, ect......
