Exhaust mani gasket to head blow out?
Old Jun 17, 2006 | 11:17 AM
BoostWhore's Avatar
I was barely on the gas just normal driving and i heard what sounded like metal shoot through the exhaust, i then noticed an exhaust leak at the head and the exhaust mani. Has anyone ever had there gasket break and shoot through the turbo? Im hoping its just the gasket, im on the stock manifold and turbo still. None of my manifold bolts are broke.
Old Jun 17, 2006 | 11:37 AM
bluebyu36's Avatar
wow
Old Jun 17, 2006 | 01:01 PM
Ike's Avatar
Ike
Maybe you blew the welds on your intake manifold
That line will never get old for me...
Old Jun 17, 2006 | 01:03 PM
vboy425's Avatar
what is the color of the smoke come out of your exhaust ??
Old Jun 17, 2006 | 01:44 PM
BoostWhore's Avatar
The motor seems to run fine I just have a exhaust leak at the exhaust mani and the head either the gasket broke in a spot or a stud. It happen when I was barely at 5psi at about 1/2 throttle. I figured if it was the head gasket or something it would be idling ****ty and barely running.
Old Jun 18, 2006 | 12:57 PM
BoostWhore's Avatar
has anyone else had there gasket break? I still have to pull mine a part hopefully tomorrow
Old Jun 18, 2006 | 01:04 PM
HiRevnVIII's Avatar
stock manifold or aftermarket?
Old Jun 18, 2006 | 01:20 PM
BoostWhore's Avatar
stock mani aftermarket 02 without the support bracket. Dp has the pivot pt on it at the 02
Old Jun 18, 2006 | 02:16 PM
HiRevnVIII's Avatar
If it is a stock manifold, the stock head to mani gasket is a 3 layered (i believe) metal piece. No way this could break off, its is sandwiched pretty good, and is pretty stong. Aftermarket mani's come with a different type of gasket, not as good as the stock piece. I dont think you have anything to worry about, maybe a part of the aftermarket o2 gasket broke off, however you would surely notice it, as it would be VERY loud. I dont think you have anything to worry about.
Old Jun 18, 2006 | 04:09 PM
BoostWhore's Avatar
I agree i thought the stock gasket is pretty strong im hoping just for some odd reason its leaking and nothing else is wrong i will find out tomorrow when i pull it off
Old Jun 19, 2006 | 05:38 PM
BoostWhore's Avatar
found the problem one of my bolts came loose on my 02 housing and the bolt hole goes through into the hotside. WHen the bolt fell out that was the noise i heard it hitting the dp. My manifold did have a slight leak on it aswell
Old Jun 19, 2006 | 06:30 PM
HiRevnVIII's Avatar
glad you found it, i was thinking about the o2 bolt.
