No CEL after test pipe
Old Jun 19, 2006 | 10:58 PM
S1monLM's Avatar
Just installed the Espelir DP and Invidia TP, there is no o2 bung on the TP, didnt plug it back and went out for a quick drive, guess what, no CEL, am I expect to see it after a few hundred miles?
Old Jun 19, 2006 | 11:06 PM
RREvo's Avatar
Possible
Old Jun 19, 2006 | 11:07 PM
DrSmile's Avatar
It will throw a code within 100 miles
Old Jun 19, 2006 | 11:09 PM
EvoRecordSetter's Avatar
+1, it just takes a little bit of time
Old Jun 20, 2006 | 04:01 AM
Ph3n1x's Avatar
Couple of WOTs and it'll be on in no time
Old Jun 20, 2006 | 04:42 AM
Stew's Avatar
Mine took an hour to throw the code. Went to Autozone the next day, bought 2 anti-foulers for around $4 and it was fixed
Old Jun 20, 2006 | 05:20 AM
j3ffw19's Avatar
go to pepboys in there"help" section and buy 2 antifoulers and drill out the hole for one and then screw it into the other one and plug into test pipe. 2k and no problems sofar.
Old Jun 20, 2006 | 01:28 PM
S1monLM's Avatar
Yup, the light just came on an hour ago (80 miles), going to get the mechanical 02 fix, see if that would help.
Old Jun 20, 2006 | 01:45 PM
Ralph's Avatar
Mine did the same, lasted about 50-60 miles then wham its on.. :[
Old Jun 20, 2006 | 02:23 PM
dubbleugly01's Avatar
just to clarify, you have to put your sensor back into your exhaust stream somehow. You can't just buy two anti-foulers and leave the 02 sensor dangling. You posted you don't have an 02 bung on the pipe, so you'll need one of those also
