Need Help/boost leak test problems
Old Jun 20, 2006 | 04:53 PM
smoothmarine187's Avatar
Veteran: Marine Corp
I have tried to do numerous boost leak tests on my car, but every time I try and pump it up, the air goes right out of the exhaust. The only way I have been able to get it to hold any presure at all is to cap the upper intercooler pipe, but then that leaves lots of things untested. I don't have a clue what to do at this point, to make it hold pressure. It works fine on the street(I'm boosting at around 27....28 psi. I would actually like to get a solid test! I have tried turning the engine over a few times while doing the test, but that didn't help either. I'm lost here........
Old Jun 20, 2006 | 06:59 PM
anyone?
Old Jun 20, 2006 | 07:04 PM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
how do you know for sure its leaking out the exhaust?
Old Jun 21, 2006 | 03:14 AM
I know because I had someone stand behind my car and feel the air that was blowing out of it!
Old Jun 21, 2006 | 08:08 AM
Evotech8's Avatar
Did you turn your engine until you got to TDC?
All your intake valves need to be in the closed position.
Old Jun 21, 2006 | 05:22 PM
Thank You, I will try that out..........
