buschur Stage I woes
ok. bought and put in the warrtalon kit today. there were no instructions, so i did the best i could from what i could find online. one, i cant keep the boost gauge lines from popping off. Also, no matter how high i turn up the MBC, it wont boost past about 17 psi. Im thinking maybe there was an error in the MBC install, as its kind of hard to screw up installing exhaust. also, I have not sent my ECU to dynoflash yet. Help?
Here is a thread for starters that might help.
I'm running a different setup, but I have a feeling that somewhere
in the boost control circuit, might be a good place to start.
https://www.evolutionm.net/forums/sh...an+mbc+pro+evo
https://www.evolutionm.net/forums/at...chmentid=21291
that means you have the soft spring and just need to put in the stiff spring. Be sure to turn down the MBC all the way first, then put in the stiff spring and drive the car. It will start in the teens, then you can turn it up. This is normal with the Forge UNOS, since it comes with 2 springs.
I'm not sure why your boost gauge lines are coming off, though. You can definitely find multiple boost gauge install write-ups here on EvoM to verify that install. Did you secure the hoses with zip-ties? Once you get those 2 things in order, then get the flash. Or, you can wait for Al to come to LA in early September to get your base flash in person or to upgrade to a custom flash.
Seidelly
Jun 15, 2015 09:50 PM
