Just got a boost controler
Old Jul 9, 2006 | 06:23 AM
akgvr4riceater's Avatar
nooooooooooo!!! dont boost that high. also if you decide to run a aftermarket down pipe, you will get boost creap. read the forums about it. i think that the halmans pro is the best controller. holds boost great. i dont trust the fuzzy logic on a modded dsm.
Old Jul 9, 2006 | 07:54 AM
gsrboi80's Avatar
You run 28 PSI your gonna have alot more problems then trying to set up that boost controller. Your gonna lose a couple PSI toward redline boost taper my friend.
Old Jul 9, 2006 | 08:19 AM
Warrtalon's Avatar
No, this is not true. IF he reads the forum, or if YOU read the forum, you will see that a downpipe does not cause boost creep. Some people have a boost creep problem with a tubular o2 housing, but not with a downpipe. You're brand new, yet you keep answering threads with false information as if you know what you're talking about. Please stop.
Old Jul 9, 2006 | 08:33 AM
kaonashi's Avatar
i think you should have just got a mbc every profec b ive had the solenoid gets stuck open ;/
And you wouldnt have had to worry about fancy buttons
Old Jul 9, 2006 | 08:49 AM
gsrboi80's Avatar
Yea I never heard of a DP causing boost creep. As war said its mostly contributed to aftermarket O2 housings.
Old Jul 9, 2006 | 10:31 AM
bluebyu36's Avatar
the two modes on that boost controller are just 2 presets, i had that boost controller for a while. i had probelms on the dyno tuning with it now i have the hallman manual.
Old Jul 9, 2006 | 10:57 AM
evil mechanic's Avatar
i was never able to get mine working properly on my gti.
