Another Boost Question
Old Jul 15, 2006 | 01:32 PM
jnathan68's Avatar
About 2 months ago, I installed an autometer boost gauge and everything was fine (boost max was about 19psi).
2 weeks ago, I installed a Hallman Pro MBC (heavy spring) and everything was fine (had my boost tuned to 20psi and less taper).
Yesterday, I noticed that the car will not boost beyond 16psi. Thought it might be the heat (around 100 degrees out). Tested it this morning and about the same.
I am getting a boost leak tester, however, could it be something else? Boost gauge bad? Hallman MBC?
The car still seems to have good power. BTW - I have a K&N drop in filter and a Works ABE. Thanks in advance
Old Jul 15, 2006 | 01:43 PM
eve-slow's Avatar
Did you try turning your boost controller up? Also, the power feels the same?
Old Jul 15, 2006 | 01:49 PM
Warrtalon's Avatar
Cant drop to 16 unless somethin happened. Does it max out at 16psi in every gear from a low rpm roll-on?
Old Jul 15, 2006 | 01:52 PM
jnathan68's Avatar
When I originally installed the MBC, I did have to turn it up to get to 20psi. I have not turned it up anymore today because of the fear that if it is an issue with the gauge, I would be turning my boost above 20 psi (stock turbo, 91 octane).
My butt "dyno" says the car feels pretty good...almost to the point where I wouldn't have noticed. Just not sure how good my butt dyno is....
Old Jul 15, 2006 | 01:54 PM
Warrtalon's Avatar
Minimum setting gives 20psi. Cant say I've ever heard of that even on a stiff spring.
Old Jul 15, 2006 | 01:57 PM
jnathan68's Avatar
I did about 4 pulls in 2nd, 3rd and 4th gear. It might have hit 17 psi a couple times but the consistent max pressure on the gauge was 16psi with a slight taper to 15psi
Old Jul 15, 2006 | 01:59 PM
jnathan68's Avatar
No, I actually had to turn the adjustment knob on the MBC quite a few turns to get it to 20 PSI when I originally installed it.
I meant that I have not turned it today in my testing. Again, don't want to be over boosting if it is a gauge issue.
Old Jul 15, 2006 | 05:36 PM
Evotech8's Avatar
You might of got some crap stuck inside the Hallman. Unscrew the barb fitting off the bottom and check the ball and seat.
