Evolution Idle
Old Apr 27, 2003 | 03:25 PM
I4K20C's Avatar
Evolution Idle
Hey guys wussup? I was wondering what does Your Evo Idle at....
Old Apr 27, 2003 | 04:57 PM
ez76's Avatar
From a cold start it idles at 1500rpm. As things warm up it slowly goes down to about 900rpm.
From a cold start after an ECU reset it is briefly at 2000rpm and then 1500rpm as usual.
Old Apr 27, 2003 | 05:08 PM
I4K20C's Avatar
Is it better or worse if an car idles higher or lower...??
Old Apr 27, 2003 | 05:12 PM
zlancer's Avatar
anywhere between 650 and 950 is a good idle...the thing is.....does the idle jump around a lot......then there is a problem.
look on the sticker under the hood...that gives the idle RPM +/- 100 rpm (usually). so it does change.
Old Apr 27, 2003 | 05:37 PM
cky3396's Avatar
just under 1000 for me
Old Apr 27, 2003 | 08:56 PM
I4K20C's Avatar
oh kay thas good.. thnanks alot guys..
Old Apr 27, 2003 | 09:10 PM
2Cool's Avatar
Per the S-AFC right about 840-850. It was at almost 1K, but I dialed it down a bit using the idle air screw on the throttle body. 830 is about as low as it would adjust, so I backed the adjuster off a bit to get the ~850 range.
