forge rs valve
Old Jul 28, 2006 | 03:32 PM
whitersevo's Avatar
forge rs valve
just trying to get a reference.. with the rs valve.. bout how many clicks is 1 psi or bout how many clicks is good for stock boost... thnxs.
Old Jul 28, 2006 | 03:34 PM
Warrtalon's Avatar
Clicks are not relevant to PSI. The RS on stock boost can be set to minimum. If you want to go stiffer, then just adjust it until it's where you want it. There is no preset amount that can be used for every car, and the psi is not measurable without doing a boost leak test.
Old Jul 28, 2006 | 03:39 PM
whitersevo's Avatar
what I mean was wat is a good amount of turns to get close enough to hold boost with out getting compressor surge..
Old Jul 28, 2006 | 03:43 PM
scherejs's Avatar
it's probably something that you're gonna have to play with. start low and build your way up to the point right before you get surging.
Old Jul 28, 2006 | 03:45 PM
whitersevo's Avatar
yeah that makes sense... ^^^ ty
Old Jul 28, 2006 | 05:56 PM
whitersevo's Avatar
so. I must be really slow..but I dont understand this.. I put the forge rs valve on and just put it at the lowest setting.. drove it around and watch my boost gauge and spiked to 23 and then leveled out at 20... now what am I doing wrong.... I mean i have no clue wat the fluttering sound makes.. and just lost help me please so i dont mess my turbo lol...
Old Jul 28, 2006 | 05:59 PM
gaulrich2003's Avatar
Mike at Forge told me to start at 21 clicks.
Old Jul 28, 2006 | 06:00 PM
scherejs's Avatar
You'll mainly hear/notice it at lower boost levels and part throttle. You'll definetely notice it when it happens especially if you have a cone filter on.
Old Jul 28, 2006 | 06:03 PM
whitersevo's Avatar
no cone filter here... just the replace the valve.... as for hearing it.... i can hear the valve let out boost .. still need some useful info.
Old Jul 28, 2006 | 06:06 PM
scherejs's Avatar
If it's spiking at 23 and leveling out at 20 then what's the problem?
Old Jul 28, 2006 | 06:22 PM
BADEVO's Avatar
I'm thinking the same thing.
Also:
Are you confusing the BOV with an MBC? The RS doesnt control your boost level.
Old Jul 28, 2006 | 06:36 PM
Warrtalon's Avatar
Yeah, I don't know what you're asking. I gave you the answers in the first reply, then that answer has been repeated multiple times. The Forge UNOS MBC is what sets your boost. The BOV just holds it without leaking until you let off the gas. What's wrong with running 23->20 psi, and why are you afraid of hurting your turbo? If you tighten it too much, then it will start causing compressor surge, which can be felt as bucking when letting off from part throttle/partial boost.
Old Jul 28, 2006 | 06:57 PM
BADEVO's Avatar
JUST to be clear
RS VALVE.... Blow off valve.
The Forge RS valve has been specifically designed and engineered, to offer extreme flow rate capability, where other valves are just not up to it. Often when engines have been tuned by installing larger turbos or even software upgrades improved turbo response can be acheived by fitting the RS valve which has the greater internal mass air flow specification utilising an amazing 50mm (2") bore.
For fine tuning there is a variable spring preload incorporated and a ratchet type top adjuster that will allow for the positive and precise adjustment that your driving style demands. To ease installation a 360 degree adjustable vacuum hose connector
With a choice of inlet and outlet connections the RS valve can be matched to your engine perfectly
This valve incorporates a unique conical, progressive rate spring that can allow for the retention of boost pressure from 7 to 34 PSI depending on the individual user's application and level of adjustment.
Old Jul 28, 2006 | 06:59 PM
BADEVO's Avatar
This is is the manual boost controller
Old Jul 28, 2006 | 07:11 PM
evo-boy's Avatar
lol, i love the picture refrences. i have the rs valve and i have it set all the way at the lowest setting on the spring that is recommended for the evo. also i dont know what mods you have but the evo is built to spike and go down like you said.
from what ive heard nothing seems to be wrong with the valve itself.....
