Hid Recommendations
Old Aug 18, 2006 | 01:49 PM
LanEvoIX's Avatar
Hey Bigl4201, I saw your post with the result. The xenondepot kit looks awesome. I'm just debating because the kit is pretty expensive. How much did you pay for installation of your kit?
I read somewhere to stay away from xetronic kits.
Old Aug 18, 2006 | 01:59 PM
tvbf1's Avatar
The stock HID uses 4300K.
I know what you're saying about getting as much light as possible so what I was thinking about is to convert the fog lights into HID also and use the 3000K bulb (the Golden Yellow Color). I live in the CA valley and it get foggy in the winter I've read that the 3000K helps you see better in the fog but i'm not sure if it's possible or not.
Has anyone ever done this? Can you give some comments on it?
Old Aug 18, 2006 | 02:04 PM
sloweclipse's Avatar
From personal experience, Kaixen is the best. I tried Eagle, MCcolough (sp?), xetronic and have seen a bunch of others. Kaixen is by far the best in finish and quality, also has the best packaging of them all. My friend also owns a detailing shop and installs HID kits as a part of his business, he also says Kaixen is the best HID kit he has seen as in finish and quality.
It comes with a fuse, no cutting splicing necessary and uses Diamond cut bulbs which from my understanding only Philips offers for OEM applications at the moment.
Unless you compare all the kits infront of you, any kit you buy and install at first will seem/look good.
Old Aug 18, 2006 | 03:19 PM
Bigl4201's Avatar
it is expensive but you get wht you pay for... PERIOD. Its all philips parts and i paid a guy i know 150 to put them in for me.
what part on NY are you in, i would be glad to show you them in person if you are close enough. I could even bring you to the guy who put mine in.
Old Aug 18, 2006 | 05:33 PM
LanEvoIX's Avatar
i think i'm leaning towards xenondepot or kaixen for a kit. I live in queens ny, around the Bayside area. I was going to get Gil from evo-ny to install them. he comes highly recommened on the forums.
Old Aug 18, 2006 | 06:05 PM
Bigl4201's Avatar
im in suffolk county (huntington). So if you would like to meet up and see mine in person i would be willing to meet up
Old Aug 18, 2006 | 11:15 PM
badhabit90's Avatar
Cool
wow. if you can change your own oil, you could have done this install. yes, its that easy.
Old Aug 19, 2006 | 09:33 AM
Bigl4201's Avatar
relax pal. Im always working and didnt have time.
Old Aug 20, 2006 | 06:57 PM
badhabit90's Avatar
hahahahaah!!!! just playing!!! it literaly took only 20 minutes to install.
unplug your lights
clean new bulbs
insert bulbs into your housings and secure
plug in the ballasts
tuck away/secure ballasts
zip tie all wires down and trim zip ties
10mm wrench to connect +and - wires battery
BAMMMMMMM!!!! YOUR DONE!! EASY FELLA EASY!!!
