My story from the evo vs wrx shootout
Read my post number #12. I have had almost all kind of engine and tranny failures on many cars. There are somethings that are loud as hell and could be misleading. You need to roll your car in neutral that would tell you where the sounds is coming from. Assume anything from broken transfer case,broken driveshaft, broken clutch asseembly,broken main center driveshaft, etc, etc.
My friend Steve twisted his rear axles on his Eagle talon 2 months ago, you can't never rule out any component
Carlos
Carlos
Originally Posted by Silver05Bullet
yeah kind of under the car kind of in the rear
whats a center carrier bearing bracket?
You will find said "bracket" and bearing in the middle of the car, (between the front and rear doors)
nah its only whne the car is moving and it sound more of under the car in the back most people said it might be that i broke an axel wider tires and actually sticking to the ground
sounds like its a spun bearing to me too.
TO check put the car in neutral and rev it up while your sitting still. If it still makes the noise then you more then likely spun a bearing... let us know.
Here is a diagram of what it could be. different parts of the driveshaft. You have to go lay under your car, and pull down and push up on the driveshaft, and get it to reproduce the noise. you will hear the familiar "clanking" again, if this is in fact the problem.
http://www.4g63t.net/2005_FSM/GR00001200-25.pdf
i saw your car in a driveway
i said to my friend wow hes lucky he lives close to the track
then i saw the house and said nah thats a broken evo
haha
sorry about the issue man
your car looked good over by the food stands though
haha
anyone have a picture of the underside of the car i think theres a piece missing from close to the transfer case it seems like im missing a bolt or something above the driveshaft its weird there is a whole for a screw but no screw and i didnt find nothing near where the car broke
standing by.
