Lost some boost
Old Aug 29, 2006 | 01:35 PM
USMCEVO's Avatar
Lost some boost
I went on a roadtrip recently and noticed that I wasnt push'n as much air. I went from 22lbs to 19-20lbs. Everything looks OK. Any comments what it could be?
Old Aug 29, 2006 | 01:40 PM
Daniel_4g63's Avatar
check your hose clamps could be a small boost leak
Old Aug 29, 2006 | 01:45 PM
newbieEVO8's Avatar
Need more detail to offer better advice. i.e. when does it happen, what rpm?
Did you break the snorkle clips?
Old Aug 29, 2006 | 01:52 PM
USMCEVO's Avatar
It used to peak at 22 psi at appox 3500rpm, anything above that it would stay at 22. I made sure the hoses were tight. It acts just like it did before but less pressure. Snorkal clips?
Old Aug 29, 2006 | 02:41 PM
gsrboi80's Avatar
Boost leak test?
Old Aug 30, 2006 | 08:30 PM
EnJaNir's Avatar
Look here
https://www.evolutionm.net/forums/sh...d.php?t=216984
I too have recently had this happen
-Temp change minimal
-Zero changes to car except oil change (done by myself)
-Now noticable turbo spool and valve function (stock turbo/stock intake)
-Loss of pressure
