Need Opinions: nitrous wet or dry?
Old Aug 29, 2006 | 05:36 PM
psphinx81's Avatar
ok well im that really that into the whole nitrous thing or dont really know that much about it, but i know enough.. now on evos, what would be better. ive been told that a dry kit would be better but would need upgraded injectors and fuel pump.. now ive been told by others that a wet kit would be better and i wouldnt need to upgrade my injectors and it would be safer
?? im puzzled as to who really knows more as to who is right and who isnt
can anyone help me here?
Old Aug 29, 2006 | 05:39 PM
dbdude's Avatar
I think we are suppost to run wet kits on turbo cars.
Old Aug 29, 2006 | 05:44 PM
gl4662's Avatar
What is the difference if I may ask?
Old Aug 29, 2006 | 05:50 PM
psphinx81's Avatar
with a dry system, nitrous is only sprayed into the air intake where it changes into a gas, the OEM FI is tricked into supplying more fuel to the engine which compensates for nitrous
WET: nitrous and extra fuel are injected into the air inlet through a common nozzle in which fuel and air mixture is distributed normally through the factory electronic FI
Old Aug 29, 2006 | 05:51 PM
3SgteGuru's Avatar
Um a wet Direct Port is the best for turbo cars, and you need to do alot of tuning an the kits are expensive, you can get a similare, but less effective effect for alot less money, Just increase the boost and get the car retuned. and a plus is you don't have to push a button. I don't know what kinda mods you got but usualy nitrous isn't realy needed for a street aplication.
Old Aug 29, 2006 | 05:57 PM
scoob2evo's Avatar
If I were you I would look into Methonal (pardon the spelling) injection. I would reccommend that above anything else. More boost with less knocking, plus its half the cost.
Old Aug 29, 2006 | 05:58 PM
psphinx81's Avatar
manifold, o2 housing, DP, cat delete, catback, walbro 255, intake, bov.. ive been reflashed and at 21 PSI.. if i got the nitrous i wouldnt be running a button, it would be a WOT switch and Two Stage RPM Window/TPS Switch
Old Aug 29, 2006 | 06:03 PM
psphinx81's Avatar
but with the meth kit ive also heard that it can be only safely tuned with a ecutek tune on the stock turbo??
Old Aug 29, 2006 | 06:07 PM
Turbo Meg's Avatar
Not correct! Al at Dynoflash does great Alky tunes! Send him a pm
Old Aug 29, 2006 | 06:11 PM
psphinx81's Avatar
alright thats what i thought, thanks.. still wondering about the nitrous.. it would only be a 75 shot as well
Old Aug 29, 2006 | 06:14 PM
Turbo Meg's Avatar
Most people don't run nitrous on a turbo car. It makes more sense to run some race gas and turn up the boost. If you must us the nitrous use a WET kit with a fuel pressure fail safe. That way if your fuel pressure drops it will shut down the nitrous. it may just save your motor.
good luck
Spooldyou's Avatar
manifold, o2 housing, DP, cat delete, catback.. ive been reflashed and at 21 PSI.. if i got the nitrous i wouldnt be running a button, it would be a WOT switch and Two Stage RPM Window/TPS Switch
Suuuuuuuuuuure you are. bet you didnt do the research to back that one up. I would go with a nice alky kit. By the time your done it like 600 . much safer and cheaper
Old Aug 29, 2006 | 06:15 PM
Turbo Meg's Avatar
I would stay small a 35 or 50 shot!
Old Aug 29, 2006 | 06:18 PM
dbdude's Avatar
If only the alky pump motor was 100% failsafe.....
gsrboi80's Avatar
Allky is the way to go. Not too many around evom run nitrous. Basic mods, allky, crank the boost and call Al (or any other tuner with allky/meth experience) Most kits now have a bunch of saftey featues built in too.
