Evo In the Snow
Old May 3, 2003 | 08:53 AM
Evo11V's Avatar
Veteran: Army
Question Evo In the Snow
Hey, Has any one tryed the Evo8 in the snow? Obviously with ~SNOW TIRES~.I'm sure its pretty good but I'm curious to find out if anyone has yet? Any recomendations for performance winter tires?
Old May 3, 2003 | 09:25 AM
OZevoVII's Avatar
i have heard they are pretty ****ty with the oem tires...im pretty sure it is a horse if a different color with some all-weather treads.
Old May 3, 2003 | 09:29 AM
MalibuJack's Avatar
Dude.. I drove my car on the factory tires in the snow.. its HORRID.. However with a good set of M&S tires that have a bit of bite, it should be able to get through most snow situations.. The traction problem had nothing to do with the car. just the tires.. You just can't beat awd in less than perfect driving conditions..
Old May 3, 2003 | 01:22 PM
Evo11V's Avatar
Veteran: Army
yes good point jack, But as far as the car set up with ridged frame and stuff, Just woundering how it would react in the snow with some nice winter tires
Old May 3, 2003 | 04:42 PM
josh's Avatar
hey
based on experinces with other cars in the snow, it will probably be pretty good. it will not be as nice as say, an audi, but not much worse either. the stiffer suspension will make it want to brea loose more often on real slick roads, but the long travel suspension should be nice for rutted snowy roads.
i wish there was someone who had put snow tires on and gave a review. it is easy to see how the stock rubber would be horrid on snow and ice. and awd car with those tires would suck.
josh
Old May 3, 2003 | 05:52 PM
WestSideBilly's Avatar
El Jefe
Snow tires or not, you shouldn't be going fast enough to unsettle the suspension when driving in the snow. You're not a rally driver, don't try to drive like it.
Look in the wheels/suspension area under Evo Tech, there are a couple discussions of snow tires. Basically, the A046s suck in the snow (obviously). The biggest difficulty will be getting 17" snow tires, since 16" rims are generally too small to get over the brakes. If you don't plan on seeing a lot of snow, a good set of performance all-season tires should suffice for winter duty.
Old May 4, 2003 | 04:57 PM
RA29's Avatar
Drove it in the snow before with the stock summer tires and they sucked. The AWD helped a little but you most definitely want snow tires or at least some good all-season tires.
Old May 4, 2003 | 05:13 PM
tryandcatchme's Avatar
Can somebody say Wintersport M2's?
Old May 4, 2003 | 11:20 PM
vz64's Avatar
Pirelli SnowSport are quite good and they do come in 235/45/17.
I had them this snowy winter (Ontario) and they did the job. They also not bad on a dry road.
