ticking noise coming from inside valve cover..
i hear a small ticking noise..when at idle...all i did was change oil to royal purple yesterday,car still feels fine but anyone know what it is?i havent took off valve cover to work on it so everythings together in there..anyone know what this could be?thanks
I have heard this many times with the use of that oil. The lifters are picky on the oil run through them and will tick if weight is too thin. I would try going back to stock or 15w Mobil1 next time. Or you could add a qt of a thicker wt in your current oil and drain the same.
Probably a lifter. At oil change time the oil pump pumps air until the filter is full. Air can get trapped in a lifter and it can take days for it to all bleed out. If the noise doesn't go away after a few days then a particle of dirt has lodged there. This still isn't a concern until the knock sensor gets involved.
Warm the car up and follow the Mitsu procedure to quiet the lifter tick and see if it helps.
Basically run the car smoothly up to 3000 RPM for a second and let it come back down. Repeat about 20 or 30 times.
