starting problem??
Old Sep 7, 2006 | 03:36 PM
bechbum82's Avatar
starting problem??
ill get to the point, some times when i go out to start the car it wont kick over at all. no sound at all. not even like its trying to turn over. I changed out the sparkplugs, and those were pretty much shot. The problem stopped for about a week, and today when i went to start it to leave work it did it again.
It usually take turning the key off and then turning it back on once or twice before it starts, when it does this. It doesnt happen all the time now, but before it starts to do it worse i want to nip it in the butt....
any input or suggestions would be helpful. i leaning torwards maybe the start?? but i am not 100% sure
steve
Old Sep 7, 2006 | 03:47 PM
IEXCELR8's Avatar
Battery cable lose or maybe a ground.
Old Sep 7, 2006 | 04:08 PM
Dapper Dan's Avatar
check your baterry and all connections with it......then check your alternator
Old Sep 7, 2006 | 04:17 PM
SASD209's Avatar
Admin Alumni
Well, I would say if your car is under warranty and you feel good bringing it back to the dealer, then do so, but with your list of mods, you probably don't want to do that. I'm thinking battery/starter or something electrical? Any electricians at work that may want to take a look? Well, good luck anyways, and let us know how it turns out.
Semper Paratus, and from an American, thanks for your service!
Old Sep 7, 2006 | 04:21 PM
smokedmustang's Avatar
My car died at the autox track. it was the "fuseable" link down by the starter, goes to it. I just had mine hard-wired into the starter, no problems since. 50K miles like that. same problem as you, check the fuse there. under the car next to the starter.
Old Sep 7, 2006 | 04:23 PM
caligula's Avatar
starter relay maybe crapping out at times.
Old Sep 7, 2006 | 04:24 PM
SASD209's Avatar
Admin Alumni
I am but I want to say , love the avatar, I picture my kitties like that after I work a double shift and forget to fill their food bowls!!!!
Old Sep 7, 2006 | 04:31 PM
kmcconn9's Avatar
Whatever it is is pretty weird. It was doing it right before we changed the spark plugs (50k on stock)...and let it sit for awahile and all was good. So I doubt that it is something with a fuse, as either the fuse is blown or it isnt....there isnt an inbetween.
But help is on the way and I will bring my meter to get things figured out....
I will report back when we find the troublesome little bugger...
Old Sep 7, 2006 | 04:38 PM
They probably do! Look for bullet holes. Here is some more cat stuff.
Ok, now what was the question again?
Old Sep 7, 2006 | 04:42 PM
SASD209's Avatar
Admin Alumni
The last one was a little fu**** up, (only cause I was thinking of kittens) but cool nonetheless!!!!
Old Sep 7, 2006 | 05:34 PM
bechbum82's Avatar
aight thanks guys.....anything else that is related
sure you were thinking of kittens.
Old Sep 7, 2006 | 05:35 PM
that was just an "intermission", I thought you were checking the fuseable link under the car. did you go look? was the fuse blown? shorted out?
Old Sep 7, 2006 | 05:37 PM
I just re-read it, and can't figure out how the plugs changed it. I say its NOT under your car, but a problem inside your ignition itself. where the key goes. wasn't there a Tech. service bulletin on those?? I would take it to the dealership.
Old Sep 7, 2006 | 08:48 PM
Gonzo0991's Avatar
I had the same problem turned out to be a socket that had fallen ontop of my starter. take off the starter cover and check it.
