Evo PRoblem
Old Sep 9, 2006 | 10:05 PM
Cali2MDevo8's Avatar
Registered User
Evo PRoblem
Hey guys,
I had a problem w/ the evo today. I haven't drove it since Monday and the car is garage kept. It's an 05 w/ 11k milage on it. Most of the miles are from the first few months I have had it. Bought the car last October. So here is the problem:
I pulled out the garage today and starting driving down my street at about 10-15mph and noticed a thumping noice like a tire makes when it's flat. Got out of the car and no tires were flat. I tried to see if maybe a lug nut was loose, but that was negative also.
So i take off slowly and hear it again, so i stop and get the girlfriend to open the door while i'm driving slowly to see if she can see or hear something a little more clearer. NOTHING. So i turn around and head back to the garage and pull car to garage and see black smoke coming out the tailpipe (car is off).
I was trying to make it to a friends house and was running late so i took my other car. Came home and checked the oil or to see if maybe one of my pipes popped off (boost leak). None of the above. I turned the car on and reved to about 3 K w/ no weird noises. Anybody have the same problem? Any help would be helpful before i send it to the stealership?
Sorry for the long post but i did make paragraphs. Also car is COMPLETELY STOCK!
Jason
Old Sep 9, 2006 | 11:16 PM
Golovko's Avatar
Originally Posted by Cali2MDevo8
Hey guys,
Jason
i think its just normal...everything just kinda 'settles' when the car sits around for too long and the motor doesn't run.
Old Sep 9, 2006 | 11:22 PM
Evolved Monkey's Avatar
No this is definately not normal. I left my car sitting for a few weeks while on vacation and she ran just as well as the day I left. Maybe something got stuck to your wheels or driveshaft. You should take it to a mechanic to take a look.
Old Sep 9, 2006 | 11:47 PM
TxEvo8's Avatar
It is still under warranty, so drive it around a little, and if it continues take it to the dealer.
Old Sep 9, 2006 | 11:56 PM
evo/X's Avatar
drive like 5 miles...and rev it up
Old Sep 10, 2006 | 01:38 PM
Registered User
Called my father who owns his own mechanic shop and has like 32 years mechanic experience but lives 35 miles away said it doesn't sound like a engine problem. He said to check the tires of something stuck in tire ( i did the glance check last night but nothing). Will keep everyone updated.
Yes it's still under warranty but you know how that goes. Maybe they will void my warranty for a shorty antenna and window tint. LOL
Bump for more suggestions. Also i went on vacation a few weeks ago and it sat for 8 days withouth a problem.
Old Sep 10, 2006 | 01:48 PM
cj1977's Avatar
Maybe you should take it to a dealership. You wouldn't want to be stranded someone far from your home.
Old Sep 10, 2006 | 02:01 PM
JohnEB's Avatar
+1
Old Sep 10, 2006 | 02:08 PM
WrX Kila's Avatar
It depends on the temp believe it ot not! I used to hear the same thumping sound when I drove my car in the morning. I had the YoKO advans on... when it got warm it went away. Those tires are excellent IN WARM WEATHER!!
Old Sep 10, 2006 | 02:32 PM
EvoDan's Avatar
The thumping noise you hear is most likely because your tires have flat spotted due to sitting for a few days. Why you didn't experiance this when you went on vacation, I dont know. But this isnt uncommon, just drive it around a little and it will go away.
Old Sep 10, 2006 | 03:38 PM
Registered User
Drove it around slowly and still heard the thumping coming from the rear, most likely the passenger rear. After a while the car stopped making the noise. No black smoke coming from the tailpipe. Not sure it's the tires from "flat spots". I drive my civic to work alot and the evo sits for a few days each week. Anyway, i believe it is located somewhere with the tires/wheels/rotor area. Will take to shop and put up on lift to make sure everything is ok tomorrow. Thanks for the help fella's.
Old Sep 10, 2006 | 03:51 PM
WrX Kila's Avatar
Most likely it was your tires that was not warmed up.
Old Sep 10, 2006 | 07:50 PM
Golovko's Avatar
so looks like i was right?
