Evo 9 w/ Carbon Fiber Hood.
I'm looking into getting a Seibon OEM Style CF Hood for my evo. But on the 9s, the sprayer tank is located in the trunk, so the wiper sprayers are routed differently. Are there those little clips on the underside of the hood to guide the hose on? If not how do you guys route the sprayer hoses? Secondly, are the wiper sprayers hard to remove?
On all USM Evos the windshield washer reservoir tank is mounted in the truck. You should have no problem with the washer tubing routing...I'd be more concerned with the fact that the VIIIs have a pointed hood and the IXs are flat at the front...
Originally Posted by Varrius
My IX hood is identical to my Evo 8s hood. . .
I apologize then, I guess i was thinking of the Evo 7's hood which is not pointed at the front. So, If you have an VIII how did you not know that the windshield fluid is in the back?
Originally Posted by gsrboi80
All windshield sprayers are in the trunk VIII and IX. 03-04 had the IC sprayer under the hood. Evo VIII and IX hoods are totally interchangeable. FYI
So are the sprayer nozzles easy to clip off?
Originally Posted by tirbolag9
might wanna check with seibon. i've seen some CF hoods requiring to drill out the hole for the spray nozzles. as for spray nozzles on the stock, not sure but i'll chime in once i check it.
Originally Posted by MREvOTard
is it true the cf hoods weigh more or same compared to stock?
https://www.evolutionm.net/forums/sh...bon+fiber+hood
Some cf hoods might weigh more than OEM. Make sure it's lighter before you buy.
Originally Posted by chaotichoax
The hood does have holes but they are NOT punched out for you. My buddy had to punch his out they just outline the cut.
