Clutch Pedel Prob??
Old Sep 12, 2006 | 07:16 PM
LancerevoIX2006's Avatar
Clutch Pedel Prob??
Okay here is the problem..
when u get in the car and sit down.. and when u press the clutch it feels like ur pushing air and it just sticks to the ground but then the car starts .... and when the car strts the pedel is stuck to floor and u cant hear the clutch(twin disc) so im like hmmmmmm... i took off the bumper and lights and turned on the car and it did this...
Old Sep 12, 2006 | 07:25 PM
3SgteGuru's Avatar
I think you need a Clutch Slave cylnder or master Cylnder, kinda easy to fix. i know You Have Air in the System, did you install the clutch today, if so did you bleed the clutch line?
Old Sep 12, 2006 | 07:27 PM
smokedmustang's Avatar
No, the clutch pedal on the floor, will HIT the switch, so you can start the car. YOU HAVE air in the system, re-bleed it, you will be fine. It happened to me also.
Old Sep 12, 2006 | 07:28 PM
didnt touch it
Old Sep 12, 2006 | 07:30 PM
DanJ's Avatar
+! to air in the clutch system, try bleeding it a few times.
Old Sep 12, 2006 | 07:32 PM
hmm kool i would try it but i dunt kno what im doing
Old Sep 12, 2006 | 07:34 PM
3SgteGuru's Avatar
One sec Let get more info you instaled the Clutch today? If you Answer no to that, you probaly blew a clutch line (unlikely), Need a clutchmaster cylnder or brake master cylnder (not to likely either), or need a Clutch Slave Cylnder ( very likely). If you answer yes to the question, how did you install the Clutch without removing the Tranny, I realy want to know.
Old Sep 12, 2006 | 07:35 PM
Let a dealer do it then, gravity feed system. don't mess with it. I had mine towed in, and fixed, easy enough. relax, and dont try it yourself if you are unfamiliar with it.
Old Sep 12, 2006 | 07:36 PM
clutch is old installed by devo tuning...
Old Sep 12, 2006 | 07:37 PM
If you crack open the tranny 1-2", you can beat a clutch up in there, like sliding a pizza under a closed door!!
yeah let me tow it i only have a GT35R in there w. a aftermarket clutch and only 5k miles on the car
Old Sep 12, 2006 | 07:39 PM
3SgteGuru's Avatar
BS Get a Guy in the Car, tell him Pump it, he pumps like 3 or 4 times, you say hold it, he holds it. You open the Bleeder valve it on the Clutch Slave Cylnder. Repeat until clutch is back to normay. if this doesn't work replace the clutch slave cylnder, they are cheap and its easy to do.
Old Sep 12, 2006 | 07:41 PM
i was getting suspesnion done at devo so i guess adam will do it
Old Sep 12, 2006 | 07:45 PM
3SgteGuru's Avatar
ok thats good cause the Dealer will rip you on the Price, they charged one of my customer 300 dolars just to bleed it. I was like WTF.
Old Sep 12, 2006 | 07:47 PM
lol holy crap... adam better not chrg me that much
