bolts!!!!
Old Sep 15, 2006 | 10:58 PM
EVOLUTION Vlll's Avatar
bolts!!!!
ok..i try to install arc heat shield today..
and while taking the bolts out.....this bolt got stuck and wouldnt come out..
then finally it broke leaving the piece in side...WTF..
now the bolt got stuck in the hole on header..
what should i do im really freaking pissed off now...
and the other thing this ****ty bolts woudlnt even fit in after taking out...
help me out here..
Old Sep 15, 2006 | 11:07 PM
eve-slow's Avatar
You're going to have to tap that beatch outta there.
I have the Buschur sheild and I tried taking it off after a few months and I could tell that they would break if I put enough torque on it.
Old Sep 15, 2006 | 11:36 PM
how did u take it out brother?
Old Sep 16, 2006 | 01:04 AM
DontRevMe's Avatar
drill it and tap it. I always coat exhaust related bolts with wd40 for atleast a few hrs before an install. PITA
Old Sep 16, 2006 | 01:05 AM
TogueMonster's Avatar
Yup drill it out, use oil. Good luck.
Old Sep 16, 2006 | 04:10 AM
x838nwy's Avatar
There's a type of drill bit called and 'easyout'. It's an extractor which is a sort of drillbit but not quite. Used for removing problems such as this one. Just go to a local hardware store and you should find it no probs.
Old Sep 16, 2006 | 06:51 PM
eve-slow's Avatar
Yep, all the advice is right on.
Old Sep 18, 2006 | 12:24 PM
trinydex's Avatar
also make sure to use antiseize on all your exhaust components including o2 sensors. coat those threads with the permatex stuff and you'll never have such a problem again.
Old Sep 18, 2006 | 12:35 PM
Ev0ikon's Avatar
IbeDrillingMyMani tonight :P
Be careful and go slow. Don't slip and drop your drillbit on the turbo housing :}
Old Sep 18, 2006 | 12:37 PM
ksuchewie's Avatar
use antisieze when installing bolts that come in contact with cold/heat/dirt/grime/fluids/etc.
Old Sep 18, 2006 | 02:15 PM
tsair's Avatar
you can also put some penetrating oil on there to loosen up the seizing a bit.
But yeah, need to drill it out. Be careful you don't mess up the threads.
