What is a good octane# for an untuned evo??
I do have a dynoflash reflash. I dont know if it was tuned for 91 or 93 pump gas. I plan on going to the track again soon. But this time i want to run some sunnoco race gas unleaded. They have many octanes available. What do you guys recommend since im not tuned for race gas? What PSI should i bump it up to? I do not have ARP headstuds. Is there even a benefit for me? Hopefully this time i can break into the 7's at the 1/8 mile dragstrip.
You could run 100 octane. I wouldnt boost it over 23 lbs all the time without head studs. Though you probably could on 100 octane. You should have a wideband to monitor A/F's as well
If your racing on a road course I would run 100 or higher and set my boost between 19-20 psi as cheap insurance. i recently was driving on a very agressive road with 318 curves in 11 mi (the Dragon), I was running 3 parts 110 to 1 part 93 w/ 25 psi of boost, but my car was tuned for 21.5 on 93 oct(i have head studs)
Originally Posted by kreionic
I don't think Al flashes for octane I thought thats only the custom tunes. When He did mine awhile back he never asked about the octane.
Originally Posted by Rnm
You'll be wasting your money if you dump in 100 octane and don't raise your boost for the drag strip.
1st...anytime you flash it has to be for a specific oct. othwise what do you tune AFRs to?
2nd...going higher octane is generally a safe way to do things, but too rich and youll effectively clean off your cylinder walls of oil.
Originally Posted by dbdude
So running race gas alone dont do anything for acceleration without raising the boost? Wouldnt it help eliminate knock or something like that?
