what size torx tip for 6spd?
Old Sep 24, 2006 | 02:44 PM
19psi's Avatar
I've noticed that that drain plug(tranny) for the mr's are not standard hex.
What size torx tip should I be looking for?
Thanks in advance.
Old Sep 24, 2006 | 05:15 PM
19psi's Avatar
surely someone has to know..
Old Sep 25, 2006 | 08:25 AM
19psi's Avatar
man....you guys are no help.
I found it though.
For those of you with a mr, the tranny drain plug and fill plug is a 3/8 allen wrench.
A standard hex socket will not work so keep this in mind before you attempt to
change your tranny fluid.
Old Sep 25, 2006 | 12:28 PM
althemean's Avatar
can you take pics? I am curious as to the difference between the 5 -6 speeds. I wonder why they switched the plugs to allen keys (which are not torx as you originally stated) instead of using the regular drain bolts.
Old Sep 25, 2006 | 01:07 PM
19psi's Avatar
iam gonna be doing the whole drive train fluid change this weekend.
I'll post some pics some on monday.
Let's just hope I dont forget my cam.
Yes I know, it's not a torx tip. It's a 3/8 allen key .
Old Sep 25, 2006 | 01:37 PM
oguratevo's Avatar
I doing MR tranny fluid change soon, it looks like 8mm or 10mm hex bit.
Old Sep 25, 2006 | 02:03 PM
Steve_P's Avatar
if a 3/8 fits you should be using a 10 mm. Very close but it's going to be metric
