Turbo Upgrades
Old May 11, 2003 | 06:54 PM
lil'evil_evo's Avatar
Turbo Upgrades
So what's up with this web site. I found it using yahoo. Has anyone else seen this? Looks like a decent site.
http://www.turboperformance.net/bsp/default.asp
Old May 11, 2003 | 10:13 PM
ferrarokid's Avatar
Thumbs up did i see turbo upgrades already ? ?
450 & 500 hp here we go....
Old May 11, 2003 | 10:30 PM
Daveyd's Avatar
would like to see some dyno results of the ECU upgrade...
thuan's Avatar
time to save up some money 3k
550 Hp upgrade sound really great about now
wonder whats all included in the 550 hp upgrade?
Old May 11, 2003 | 11:34 PM
Wait don't all turbos made for this engine work on our cars? You would need intercooler upgrade for sure plus other work.
Old May 12, 2003 | 12:52 AM
Liandrin11's Avatar
No, I believe the turbine spins the reverse direction from normal so a turbo kit designed specifically for this car is necessary (I'm 98% sure).
Old May 12, 2003 | 01:49 AM
evoloverebdb's Avatar
But at 550 hp, wouldnt you need a new bottom end? and ECU? It seems too much for too cheap. There has to be some hidden costs. I know the 4g63 engine is almost bullet proof, but were talking double the HP here!
Old May 12, 2003 | 12:56 PM
BoostJunkie's Avatar
Take into consideration.....
Check out the HKS Evo for some idea of a mod list.
This is from Super Street online and Speed Options but you get the idea.
Links....
Super Street Article
Speed Options Article
Old May 12, 2003 | 03:50 PM
MalibuJack's Avatar
If you notice the dyno sheet.. It made about three hundred something horsepower.. They are rating the turbo upgrade as a MAX gain.. Not what your going to get.. You will certainly have to shim the head to reduce compression slightly, and do some bottom end work at the least.. if you want to go to 550hp, your talking about Cams. Fuel injector upgrades, Fuel pump upgrade, ECU upgrades (Aftermarket ECU likely), etc...
The turbo and manifold are just rated at 550hp.. I guess that is what the calculated HP Is based on the maximum (useful) boost that this turbo/manifold setup can provide..
Old May 12, 2003 | 03:51 PM
MalibuJack's Avatar
However did you notice that it was a 100+ gain over their baseline.. Though I'm uncertain what their baseline was (if it was stock, or had other modifications prior)
Turbojunkie
Northwest Region
Sep 25, 2007 09:20 PM
JUNUSA
Nov 25, 2003 10:11 PM
